Introduction: Laptop to Desktop Conversion
In this instructable, you will learn how to transform an old, broken laptop into a nice desktop. This project involves a total rework of the computer case. With this mod, you can give new life to an old laptop.In order to do this, you do not need any advanced craftmanship or tools (but if you have them, they will come handy).
Background: a friend of mine gave me a laptop for free. It had a totally broken case (hinges and all) and a dead battery. So i said... what is this useful for? A desktop, of course.
PS. This would look great wall mounted. It can also be made into a tablet (although rather heavy) by adding a commonly available touchscreen kit.
PSS. I'll add more pictures this week.
Step 1: Materials and Tools
To accomplish the mod, you will need several materials and tools. The materials are:
-Enough acrylic to cut three scree-sized panels (varies on laptop size and craftsmanship--read below)
-Four screws at least the size of the expected thickness (depending on laptop, see next steps)
-Eight nuts for the above screws; four of them normal and the other four locknuts.
-Enough screws to secure the motherboard; depends on laptop.
-Spacers (the screws used to secure the motherboard must fit in the, the size depends on the motherboard.
-A pushbutton (the new on-off switch)
-About three feet of wire.
-The most important material: a laptop.
Tools
-A drill
-A hacksaw
-Screwdriver
-Soldering Iron
-Elbow grease
Step 2: Dissasembly
Disassemble the laptop. Each laptop is different, so I cannot provide specific details. From my experience, there is almost always a screw under the keyboard that prevents you from separating both halves. At the end, you want to end with the screen, the motherboard, and things such as the hard drive and the ram. The touchpad, keyboard, and webcam will not be installed, these will be external. (Common USB keyboard)
Step 3: Front Face
Measure the screen and cut an acrylic pane larger than the screen's border. The exact amount you must leave to each side depends solely on your craftsmanship. The better you are, the less margin you will need. (Bear in mind that there must be a margin in both sides, so the final size would be the screen size plus two times the margin)
If you are like me (aka bad), leave a wide margin, around an inch to each side of the screen. This gives you a large margin in case you need to drill something again. This large sheet will be the front cover.
Then, cut some strips such that they overlap the bigger cover on the margin. This means that if you left a 1 inch border, you must cut four 1-inch thick strips and place them along the corner. The void in the center is the place where the screen will be, the strips will maintain the screen centered.
Drill four holes, one in each corner of the cover and their corresponding strip, and insert the 4 main screws. Do not insert any nut in these screws yet.
Step 4: Middle Cover
Cut another acrylic sheet, the same size as the one that corresponds to the main cover (which is the screen size + your selected margin) drill four holes at the exact same location and make sure the screws go through.
Make a slot for the screen's cable. to do this, drill four consecutive holes using the drill, and then file out the irregularities. Insert this cover on top of the screen, which should aready be residing in the front cover between the strips.
This is similar to a sandwich. At this point, you can insert the normal nuts into the screws.
Step 5: Back Plate
Now, we are going to make the back cover. First, cut an acrylic plate the same size as the front cover and middle cover. Drill the same four holes you have done with the previous layers. Then, place the motherboard over the middle cover in a way you can connect the video cable to the motherboard; the side that faced up in the original laptop (keyboard side) will most likely be facing down, towards the screen. Connect the cable from the screen to the motherboard and position the motherboard in a way such that the connectors (USB, ethernet, etc) just at the border of the sides of the acrylic.
Then, position the backplate over the motherboard and mark in the acrylic the positions where the motherboard screw holes are. Take off the back cover and drill the holes. Then, reposition the plate over the motherboard and insert the screw.
There are many screw holes in the motherboard, but if you have a bad craftmanship, you can have the consolation that you only need to line up three holes (of the eight or more that the motherboard has). Use the spacers to keep the motherboard level with the middle acrylic layer. The spacers must be present both below and above the motherboard Use the smallest spacers that can be used while still keeping everything level.
Step 6: Fan Holes
First, print a fan hole template. I used this one , resize it to your laptop's fan size. In my case, the fan was 4cm tall and 4cm wide.
Place the pattern over the fan and place lots of transparent tape over it, so that when you drill through it, the pattern does not move.
Now, remove the backplate from the rest of the assembly, place it on bench and drill the fan holes with the largest bit that you can comfortably use without risking breaking the pattern and/or the acrylic.
Step 7: Power Button
Most likely, you will have to relocate the power button. To do this, first determine where the power button was originally located. Then, solder a pair of wires to this button.
After this, solder the other ends of the same wire into the pushbutton that will act as a replacement, and then stick it through a hole drilled in the acrylic. The exact dimensions of the hole will varie on the button you choose to employ in your laptop (or desktop, as you want to look at it.
Step 8: Finish
Put all the acrylic and computer pieces together in their respective order. The top layer must be between a normal nut and a locknut . This applies only the screws at the four corners. I know my explanation is a bit unclear, but a picture is worth a thousand words.
Now you have a nice desktop (or tablet with a touchscreen kit), sit back and enjoy.
55 Comments
11 years ago on Introduction
I'd like to do this with my laptop largely because of the cooling benefits of the open case. Do you think it would be worth it? Also my laptop already has a touch screen so should I cut a hole out of the front acrylic panel to expose it?
Reply 6 months ago
You should try to slightly underclock the processor. While this will result in a slightly slower computer, it should prevent the heat issues regardless of how hard you push the remaining processing power.
Reply 11 years ago on Introduction
It's not really worth it if the only problem is cooling. This one had its case broken at multiple points as well. I'd say the only thing you need to do is to open it up, remove the fan, and clean the heat sink underneath if you have overheating issues.
Most likely the heat sink will be clogged with dust. (At least mine was)
I recently cleaned the fan and heat sink and replaced the thermal paste on the cpu and it still runs at dangerously high temperatures so I'm willing to try anything. Does your converted laptop run noticeably cooler than most laptops?
Cant compare, as it was originally broken when given to me; no reference point. Nevertheless, i'd say something else is wrong and opening up will be useless if you dont identify the problem.
-Has it always been this hot? (since bought/or is it recent)
-Is it over clocked in any way?
-Is the laptop constantly processing stuff (check processor usage in task manager)
Question 2 years ago on Introduction
If you buy a notebook Motherboard without accessories, would that be also possible to construct a PC? I do have experience using laptop screens as stand alone monitors. could connecting to 19-21 V and plugging in an external monitor suffices?
5 years ago
I am turning an old XPS laptop into a desktop it has a HDMI port but it has to have a LCD panel connected to 40 pin ribbon connect on Motherboard is there a way to turn that 40 pin port on Mother board into a VGA or HDMI port or something?
6 years ago
is it possible to convert the laptop to desktop even if the charging ic is dead?
6 years ago
I wonder if this will fit inside an old xbox gutted case
7 years ago
awesome. im planning to do this to my old one but im going to put the fans from my cooling pad (which is connected via usb) so that's what im tryin to figure out..how im gonna do that
7 years ago
I have the same laptop.
7 years ago on Introduction
Hi. This may be too late, but still. I want to do almost the same thing as yours, however I think laptop cooling system wouldnt be enough. So the question is can I mount a PC cooler onto laptop motherboard?
Reply 7 years ago
I don't think it should be a problem. Keep the original Laptop heat sink, then use thermal paste on top of that to attach a normal heat sink and fan how you going to attach it without the laptop motherboard making provisions for it, you have to workout yourself. But the thinness will greatly increase.
You can of couse do what I did. I got hold of several old laptops in a junkyard, removed the head sinks and see which would fit nicely with the original heat sink. Then I clamped the two together and attached that to the board. This means I have twice the amount of heat sinks and twice the amount of fans. (I connected the wiring of the second fan to the first fan's wiring.
Reply 7 years ago
What he said :D
8 years ago on Introduction
Hi, great instructable. I have a problem though and was wondering if you could help. I have the mother board, LCD screen, hard drive, charger and have made a case for it. It lights up, the fan spins but theres no picture coming up lights stay steady. I've tried plugging it into another screen and there is still no picture. Is it buggered or something else?
The gpu or graphics processing unit is damaged...You can fix it by using reflow ..After reflow dont use it for heavy hd gaming
11 years ago on Step 3
Ok, this question may sound idiotic, but i really feel like i missed something, ¿how did you cut the acrylic?¿did you use a laser cutter or was it with a saw? (again, sorry if it seems idiotic)
Reply 8 years ago
He probably scored and snapped it; that's what I'd do
12 years ago on Introduction
Congrats on your project mate. Just one thing, how did you get pass the dead-battery issue? I have an old laptop with broken lcd and dead battery but I dont wanna spend like $150 in fixing it, how can one get pass the battery issue? Thanks!
Reply 12 years ago on Introduction
if it's gonna be a desktop you just plug it into the charger and it'll run no problem.
as for the broken screen if it has a screen output, witch almost all laptops do,
(i mean even the $150 ones) you can just plug a screen into it. Voila!
