Introduction: Large Dice
This is an easy way to make a Dice which is almost used in every game. I thought why not use something which is recognized by most of the people and this is the first thing that came to my mind. Hope you like
Step 1: Choose the Dice Shape
There is a shape named Dice at the end of the basic shapes gallery and drag it to the workplane. You can set the size of the shape on your own. It depends upon you how much large do you want it to be.
Step 2: Choose Numbers From 1 to 6
Select the text shape and drag it to the workplane. Drag six text shapes and rename them as 1, 2, 3, 4, 5 and 6 respectively. You can use sphere as dots also but I did it in this way.
Step 3: Engrave the Numbers on the Dice
Rotate the numbers in straight position and attache it with the dice. Do the same with all the numbers and then select all of them together and click on group or do Ctrl + D. The numbers will be automatically engraved on the dice.
Step 4: Customizing
You can now customize your dice by moving it from one place to another, changing the colors and set the size. All has been done.
Step 5: My Final Dice
This is my final Dice. Hope you have understood the steps clearly.
