Introduction: Large Lego Lawn Mower
so this is a minifig scale lawn mower that the minifig can drive
what you need is a 4x8 plate, a 2x4 plate, a 2x4 trapazoid plate, a 2x2 tiles with studs, two 2x2 tiles, two 2x2 tire axles, a 1x4 tire axles, two 1x2 plates with a bar, two 1x2 plates with clips, two 1x2 plates, two 1x2 grill peices, a steering wheel peice, a 2x2 round tile with a hole in the middle, a 2x4 slope brick, a 2x4 brick, a 1x2 snot brick, a 1x2 handle bar brick, two 1x4 bricks, a tecnic pin with a stud, a 1x2 brick with a tecnic hole, and four tires
Step 1: Wheels and Axles
attach the wheels to the axles and put the 2x2 tile with studs on the 2x2 axels
Step 2: Start the Base
add the 2x4 slope brick at the front of the plate, then behind it add the 2x4 brick then on top add the trapezoid plate
Step 3: Seat
add the 2x4 plate and add the steering wheel at the front end of the plate and the bar at the back end
Step 4: Walls
add the two 2x4 bricks to the sides of the seat, then add the grill plates on the middle of the 1x4 and 2x4s
Step 5: Flaps
add the 1x2 with a clip, on the bottom of the 4x8 between the 1x4 and 2x4 bricks. to build the flap you put down the 1x2 bar plate then put a 1x2 plate on top of that then the 2x2 tile ontop of that then clip it onto the lawn mower
Step 6: The Blade
first put the pin with the stud into the brick with the hole then put the snot brick away from the pin then put the 2x2 round tile with a hole and put it on the stud then line it up so that the 2x2 round tile is in the middle. also attach the axles and the 1x4 axle is in the front and the 2x4 axle is in the back. the end
