Introduction: Large Minecraft Modern House
We are going to make a Large Minecraft House, all you need is a world in creative, or if you manage to get very much concrete white blocks
Step 1: The Outline
The outline is 48X42, first dig it in the ground then place in the ground white concrete blocks.
Step 2: The Wall
build a 3 high concrete wall, build it on the ground and one block away from the outline. do only the back and the sides, the front will be a little diffrent
Step 3: Make the Front Gate
make it like on the pictures, for the glass use pane stained grey glass.
Step 4: Entry
make the doorsteps like this, fill the space under the doorsteps. use quarts stairs, and for the blocks just use white concrete blocks.
Step 5: The Outline of the House
make the outline, fill it up and make one layer more on the northwest side.
Step 6: The Garage
get the line 2 back from the fence, then make it higher and put a roof on it, put the stone slabs as a way to enter, then make 2 doors to enter the house.
Step 7: The Infinity Pool
use again pane stained grey glass, put water in it and make a lounge. you can make a lounge yourself.
Step 8: Make the Hallway and the Front Garden
make it with grass blocks and make the layer higher so it is the same layer with the house.
Step 9: The Stairs to Heaven
make it like on the picture.
Step 10: Kitchen and Second Room
make it like a bar, then make a wall for the second room, and make it from blocks.
Step 11: Living Room
make the roof of glass and make a small stair to the higher platform. make big windows.
Step 12: The Hallway Above
use glowstone for light.
Step 13: Room Next to Infinity Pool
make it just like on the picture.
Step 14: The Bathroom
make a shower and the door like this.
Step 15: Small Room
make it like this, you can use other colors.
Step 16: End Result
first on day, and second when night.
