Introduction: Laser Cut Adjustable Table Lamp
About: Thanks for stopping by! I'm Nir, a physics PhD student studying E. coli bacteria. On my free time I enjoy making all kinds of things - from laser cutting & 3D printing to baking, cooking and doing science expe…
I love lamps, so after not having time for a new project in while, it was natural for me to make another one. When I started the project, I wasn't sure what I wanted the result to look like, so I decided to make a modular lamp. This way I could make up my mind about the design as I go.
In this instructable I'll show you how to make this adjustable table lamp (that's also modular). All the files I designed are also available here for free :)
The lamp consists of 4 main parts:
  1. The base (which I made of concrete)
  2. The arm (laser cut)
  3. The lamp holder (also laser cut)
  4. The lamp (LED & wires).
Each part of can be modified as you like, as long as you keep it compatible with the joints I made. I'll mention what that means as we go.
I hope you follow along and enjoy this project, and if you have any questions or comments, I'll be happy to reply!
Tools:
  1. 3D printer or access to one (not 100% mandatory)
  2. Laser cutter or access to one.
  3. Soldering iron & related accessories
Materials:
  1. 6mm wood (to be laser cut)
  2. x4 (four) 35mm and x1 (one) 25mm M6 bolts
  3. x5 (five) wing nuts (for M6 bolts)
  4. Cement & sand (or a smooth concrete mix)
  5. x6 (six) 3V LED's (I used these <-- affiliate link)
  6. 18V DC power supply (I used this one <-- affiliate link)
  7. 5.5mm power jacks (I used these)
  8. Electrical wire
  9. Plastic tube with a 6mm outer diameter (I used this, also not mandatory)
  10. Anti-slip stickers (I used these)
  11. Glue (wood glue & gel super glue)
Units are given in SI (international system of units) throughout the instructable. To convert to inches simply google "35mm to inch" or so. I know this may disappoint some readers :) (see here why I bother!)
Step 1: Video Version
For those who prefer a narrated video version of the project :)
Step 2: Base - 3D Printing & Laser Cutting
The lamp base is made of concrete, which requires a mold. It's made of three parts:
  • A 3D printed shell
  • A laser cut bottom plate
  • A connector for the lamp's arm
Start by 3D printing the shell (file below). I made it out of PLA and it worked great. While the printer is working, go ahead and laser cut the rest of the parts out of 6mm wood (file below).
The settings I use on my xTool D1 (10W) diode laser: 6mm plywood - power: 85%, speed: 6.5 mm/sec, passes: 3, kerf offset: 0.09mm
Step 3: Base - Assembly
  • Press the odd-looking pieces (the ones that look kind of like umbrellas) into the bottom plate, as shown in the first image.
To make sure the parts are evenly spaced and remain so while the concrete sets, I used some spacers.
  • Use wood glue to attach two spacers to the odd-pieces like shown in the second image. Then, add a third spacer to the top, this time without using glue.
  • Place the 3D printed shell onto the laser cut bottom plate (as shown in the third image).
  • To make a hole in the concrete base for the electric wire, insert a short section of a 6mm plastic tube into the hole in the 3D printed shell, and secure it away from the middle of the umbrella-looking parts using the spacer at the top (see the last image). If you don't want to thread the electric wire through the base like I did, use some tape to cover the hole in the 3D printed shell.
Step 4: Base - Casting Concrete
  • Mix cement, sand, and water to make smooth concrete.
  • Pour the concrete into the mold.
  • Make sure it's all filled, and that no air bubbles remain trapped inside.
  • After a few hours, use a knife to clean up the wooden parts (the joint) and sand the concrete to your liking (last GIF).
Step 5: Base - Demolding & Finishing Touches
  • Let the concrete harden for a few days. Be patient, or else you'll have to repeat the previous steps many times like I did.
  • Demold by removing the 3D printed shell and the bottom plate (1st & 2nd images).
  • Use a saw to cut of the finger joints from the bottom. Don't worry it's not perfect, because it's going to be hidden anyway (3rd image).
  • Clean dust off the bottom side and glue anti-slip stickers to it (4th image)
Step 6: Arm - Laser Cutting & Assembly
This step is not difficult, but hard to explain, so be sure to view the pictures along the text!
  • Cut the arms and the dedicated spacers and washers out of 6mm wood (file below).
You should have 4 long segments, 1 short segment, spacers and washers.
  • Use a 35mm M6 bolt and a wing nut to connect two of the long segments to the base (see 1st image).
  • Connect the short segment to the previous two segments: thread a washer onto a 25mm M6 bolt and use it to connect the short segment to the two long ones, as shown in the 2nd image. Insert another washer from the other side, and secure everything with a wing nut.
  • Connect the two remaining long segments to the shorter one. Sandwich the short segment with the two long segments and two spacers like so: long-spacers-short-spacer-long, and secure everything with a 35mm M6 bolt and a wing nut (3rd image).
  • Lastly, connect the previous 2 long segments to the ones attached to the base, with a spacer at the center, and two washers at either end of the 35mm M6 bolt (see 4th image). Secure everything with a wing nut.
Step 7: Lamp Holder - Laser Cutting & Assembly
  • Laser cut the lamp holder out of 6mm wood (file attached).
  • Glue the circular spacer and the two rectangular ones to one of the outer parts of the lamp holder (2nd image).
  • Once the glue dries, spread some glue on top of the spacers and glue the second outer part to the spacers, as shown in the 3rd image.
  • To connect the lamp holder to the arm, use a 35mm M6 bolt and a wing nut (you can do it now or after adding the LED's).
Step 8: Lamp - Soldering the Circuit
The schematic drawing for the circuit is shown in the first image. It's made of 6 LED's (3V each) connected in series, along with a 100 Ohm resistor to limit the current going through them. The circuit is closed with a decorative copper wire instead of a simple wire. Let's get to it!
  • Solder 6 LED's + 100 Ohm resistor in series. Notice the LED's have a positive and a negative side, usually differentiated by a small hole in one of their arms (2nd image).
  • Bend the circuit to fit the lamp and use hot glue to secure it in place. It should fit into the small holes at either end of the lamp holder (2nd image).
  • To close the circuit you could run a simple wire from the far side of the lamp holder, but I used an exposed copper wire. To follow my design, first bend a copper wire to the shape of the lamp. Then, prime its ends with solder. Finally, insert it into the lamp holder. It should fit into the small holes at either end of the lamp, but not at the same side as the LED's and the resistor (3rd image).
  • Solder the LED's to the copper wire at the far side of the lamp holder. I used a small bit of copper wire and soldered both of them to it (see 4th image).
Step 9: Lamp - Adding Wires & Power Supply
At this point, the circuit is almost done, and all we need to do is to run wires along the arm and to connect the circuit to a power supply. Before we do, it's a good idea to make sure everything is working properly! In my case about 20% of the LED's were broken upon delivery!
  • Solder electrical wires to the LED circuit (one to each of its ends, as shown in the 2nd image).
  • Run it along the lamp holder and use gel super glue to hold it in place. Make sure you leave enough slack so the elbow joints can flex freely (see 3rd image).
  • Secure the wire with a zip tie and thread it through the concrete base (4th image).
  • Lastly, solder the power jacks to the electrical wires and connect the LED's to an 18V DC power supply.
Step 10: Done!
That's it! The lamp is ready for use. I really like the soft light it gives off and that it takes all these different shapes :)
If you look back at the project, you may notice that I showed various versions of each part of the lamp along the way. Specifically, I made about 6-7 versions of the concrete base and two lamp holders. Since the lamp is built to be modular, I was able to replace them with my favorite version (see the 2nd GIF and last image). So, if you want to make changes to the design, you don't have to start from scratch - just modify the part you want to and keep the rest! :)
I hope this project inspires you to make something of your own! And if you end up making a lamp like this, I'd love to see your version in the "I Made It" section below :) Also -
If you like my instructable and want to see more laser cutting projects,
you're welcome to visit my collection of laser-cutting projects
And if you want to support my work (for free), visit my YouTube channel, see if you like what I've done so far, and consider subscribing!
See you soon :)
