Introduction: Laser Cut CD Stack
So here you will find a simple Laser Cut CD Stack
No need for screws or bolts, works entirely on the fact that it is a tight fit!
List of Materials:
1 Laser cutting machine
several 3mm wood sheets
Step 1: Cut With a Laser
access the svg- feel free to personalize the stacks backboard, just avoid doing anything to the holes.
use the svg file to cut out the shapes
Note: that you'll need top cut 12 shelves and there are only 2 in the file. copy and paste in order to get more shelves.
USE 3mm thick wood
Step 2: Tight Fit
insert the shelves into the back.
its a very tight fit some force is necessary.
fit the two front legs on the other side of the shelves
Congratulations you're done .
