Laser Cut Mini Frame Loom Weaving
18,844
150
11
Introduction: Laser Cut Mini Frame Loom Weaving
About: Our mission is to make weaving more accessible by designing open-source weaving looms. The Interlace Project is a practice-based research project by Sheffield (UK) artist Toni Buckby. Based on the history…
Welcome to The Interlace Project!
The Mini Frame Loom, has been designed to teach the basics of weaving and it's small size makes it ideal for little hands.
Follow our video tutorial or our step-by-step photo instructions to learn how to use the Mini Frame Loom to create your own weaving!
What is Weaving?
Weaving is a method of creating cloth from two sets of yarns or threads interlaced at right angles. The lengthwise threads are called the warp and the sideways threads are called the weft . Cloth is usually woven on a loom , a device that holds the warp threads taut and in parallel to each other while weft threads are woven through them.
Materials for the Loom
  • 3mm MDF 15x20cm (6x8")
Materials for Weaving
  • Wool
  • Scissors
  • Large eye wool needle
Video Tutorial
The Mini Frame Loom can be cut from a single piece of 15x20cm (6x8") 3mm MDF.
Step 1: Make a Slip Knot
Step 2: Secure the Beginning of the Warp
Step 3: Warp Up the Loom
Step 4: Secure the End of the Warp
Step 5: Weave the First Heddle Stick - Alternate Each Warp Thread Under or Over the Stick
Step 6: Push the First Heddle Stick to the Bottom of the Frame to Tension the Warp Threads
Step 7: Slide the Second Heddle Stick Into the Gap Created by the First Stick
Step 8: Push Second Heddle Stick Towards the Top of the Frame
Step 9: Weave the Third Stick Alternating the Position of the Warp Threads - the Upper Warp Threads Should Be Placed Under the Stick and the Lower Threads Placed Over the Stick
Step 10: Push the Third Heddle Stick Towards the Top of the Frame
Step 11: Wind the Weft Thread Onto the Shuttle
Step 12: Pull the Middle Stick Towards the Centre of the Frame and Turn on Its Side - This Creates the Gap (or "shed") Through Which to Weave the Weft
Step 13: Push the Shuttle Through the Shed - Make Sure to Leave Enough Weft to Allow a Needle to Be Threaded When You Come to Secure the Ends
Step 14: Remove the Middle Heddle Stick
Step 15: Use the Reed (looks Like a Comb) to Push the Weft Yarn Securely Into Place
Step 16: Pull the Top Stick to the Centre of the Frame
Step 17: Above the Middle Stick Weave the Stick You Have Just Removed, Alternating the Position of the Warp Threads - the Upper Warp Threads Should Be Placed Under the Stick and the Lower Threads Placed Over the Stick
Step 18: Turn the Middle Stick to Create the Shed and Push the Shuttle Through
Step 19: Remove the Middle Stick and Use the Reed to Push the Weft Yarn Securely Into Place
Step 20: Pull the Top Stick to the Middle and Weave the Spare Stick Above, Alternating the Warp Thread Positions
Step 21: Repeat the Process!
Step 22: To Secure the Loose Weft Ends - Thread Onto a Large Wool Needle and Weave Back Into the Cloth
Step 23: If You Run Out of Wool or Want to Change Colour You Can Weave the Loose Weft Ends Back Into the Cloth Using a Needle
Step 24: When You Have Finished Weaving Remove All the Sticks and Tie the Warp Ends Together - You Can Slide or Cut These Off the Frame
Fiber Arts Contest 2017
1 Person Made This Project!
  • Make It Bridge
    Make It Bridge
  • For the Home Contest
  • Game Design: Student Design Challenge
11 Comments
tamara.olliver
tamara.olliver
4 years ago
I've modified the design a little and made a heddle for it, do you want me to post the files and some photos?
KHHenry
KHHenry
Reply 10 months ago
I'd love to see your heddle design, please!
TheInterlaceProject
TheInterlaceProject
Reply 4 years ago
Hi Tamara
That sounds brilliant! I'd be really keen to see what you've done.
colleenjordan
colleenjordan
3 years ago
Our makerspace students fell in love with this project! I showed it to them only a day ago and they’re already talking about teaching a class for their classmates! I’m going to use this to teach about patterns and computer science history.
blawrensen
blawrensen
4 years ago on Introduction
Thanks for the great idea and for sharing the files!
I am using this today for our school STEAM Club, co-curricular (after school) activity.
Because I needed to make 24 of these, I moved parts together and deleted the extra cut lines where lines were on top of each other. The first file (with six on a 12" x 24" piece of 2.5mm plywood) took 54 minutes to cut out. By eliminating the extra cutting, the cut time was reduced to 49 minutes, saving 20 minutes total. I have found the bit of extra time to move items together and then delete one of the overlapping lines is far worth the effort, especially when cutting multiple items.
Cut out on a Epilog Helix Laser 50 watt. Settings for 2.5mm plywood: 100 P, 10 S, 400 F.
TheInterlaceProject
TheInterlaceProject
Reply 4 years ago
These look great! I hope your students enjoyed weaving - and thanks for sharing the laser files
cutelittledevil
cutelittledevil
4 years ago
I like that you used all the 'wasted' space very effective. Using the sticks to pre-weave will also make it easier to explain different wefts.
mrsmerwin
mrsmerwin
5 years ago
I like the portable size of this design. You could literally take it with you anywhere.
Glumgad
Glumgad
5 years ago
Great mix old and modern technologies!
How many time do you need to weave a pice loke that?
TheInterlaceProject
TheInterlaceProject
Reply 5 years ago
Hi Glumgad
It doesn't take long to weave - about an hour or so.
