Introduction: Laser Cut Nesting Box
A simple nesting box done by laser cut, designed specifically for Tits.
But the project includes all needed files where it’s possible to change sizes according to other species needs.
And, also includes a PDF file where you can find all references. According to RSPB and BTO, different species has its own specific needs to be usable.
Step 1: What You Need
Wood: Softwood
A3 size sheet X 2, thickness: 6mm
Extra: Cable Tie / Wire / String or etc
Step 2: 3D Model and 2D Drawing
This drawing was made for Softwood which is 6mm thickness, if your wood is thicker, you need to change all number 6 according to your material thickness. (Also layout for people who wants to do by hand)
This nesting box was made for TITS only. But the project includes all needed files where it’s possible to change sizes according to other species needs.
And, also includes a PDF file where you can find all the references. According to RSPB and BTO, different species has its own specific needs to be usable.
IMPORTANT: It depends on the material itself, after laser cut, some of the material might be to lose, the files, Rhino and Ai are with 4 small holes in the bottom to tie with 4 sides, you can also change the details if you want to.
