Laser Cut Shirt
Intro: Laser Cut Shirt
My sister and I headed down to heatsync labs in Mesa, AZ this morning to try out the laser cutter on some t-shirts!
(By the way? Do you think this is cool? Do you think huge LASERS are cool? Check out this contest that instructables is running right now: https://www.instructables.com/contest/hurricanelasers/ -- Grand prize is a laser exactly like the one we used on this project! My favorite machine in the lab! <3 Enter that contest!)
The effect is really cool, like a lace, except part of the shirt itself. We found that a 5% polyester/95% cotton blend worked best. The polyester seems to melt at the edges of the cuts, sealing them against fraying.
Cotton works as well, but care has to be taken not to fray the edges of the cuts.
See: lace.dxf if you want to cut one of these for yourself!
STEP 1: Gather Your Materials
As usual, first gather up all of your materials. For this we're using a 5% polyester/95% cotton blend t-shirt.
We also grabbed a piece of cardboard out of the scrap heap to keep the shirt rigid while we cut it.
STEP 2: Cover the Collar With Something
My sister's pattern would transit her shirt's collar with the laser on, which is a problem. Rather than try to custom fit the pattern to the shirt, we decided to just cover the collar with something that the laser wouldn't cut through. (Cover the collar with something so the laser couldn't touch it)
Our first thought was plywood. The problem with this was that our laser has a "whisker" for zeroing the z-axis. Unfortunately, the whisker travels really close to the material while cutting, and this meant that it would catch on the plywood. NO GOOD!
Instead we decided to cover it with LOTS of tape (5 layers) and hope it worked.
It did. If your laser has room for it, do plywood, otherwise tape will work.
(You can see the tape in step 4. We forgot to take a photo of it, OOPS! In it's place, please enjoy this photo of me operating a bandsaw. This was for the piece of plywood we didn't end up using.)
STEP 3: Tape the Edges of the Shirt
Stretch the shirt so that it is tight against the cardboard, and tape the edges back.
STEP 4: Load the Laser Cutter
We taped the cardboard/shirt down so that it wouldn't jostle around, and set the laser to work!
Our settings were:
Speed: 50mm/s
Power: 16watts
This seemed to work really well! Our 5 layers of tape also protected the collar! Hooray!
Our settings were:
Speed: 50mm/s
Power: 16watts
STEP 5: The Result
The result was really nice. Towards the top right, unfortunately, we cut the collar a bit :(.
Oops! This was because we started the cut at much too high of a power!
STEP 6: Try It On!
Here's the final result!
42 Comments
Trotec Laser Canada 5 years ago
ArturoR22 8 years ago
Nice!!!
mbourgon 8 years ago
Thanks for including the pattern! Making one tomorrow.
blhack 8 years ago
Let me know how it goes!
masterURlaser 8 years ago
I have just the shirt for this project! Expect an "I Made It" soon!
CKQuiver 9 years ago
An old thread... but perhaps someone might have a response for me. I'm trying to lasercut in silk, wool, linen and cotton... and it often seems that we're burning the material too much or smoke-damaging it. (without seeing smoke). Design looks clear when I take it from the laser bed.. then I rinse the burn smell and singe out... and it shrivels up like camo-netting. (It's an intricate design.) We just spent some time to get our settings right on small pieces (30 sec cut time)... and I rinsed them afterward and they were perfect. Then I moved on to larger pieces (15 min cut time) ... didn't rinse right away and * sigh * they are all shriveling up again and the fabric is degraded. I'm working in wool at speeds of 200 and power 20%/70% and in silk at 100 and power 80. The silk is not cauterizing. ... Anyone had issues with thin fabrics? Or has it been easy-peasy for You? Thx, CK
ukalar 9 years ago
kelly569 10 years ago
I'm wondering if you have any tips or advice that you might have.
from using it is there any aspects of the process that would benefit being made easier for use.
Thank you,
Kelly
moore_kellyann@yahoo.co.uk
blhack 10 years ago
Not sure how you could make it easier. This was REALLY easy! Maybe some pre-cut forms of cardboard backing?
Thank you for replying back to me,
I just have a few questions
does the laser cut deep into the cardboard?
what software did you use to design the pattern to be cut out?
davemenc 10 years ago
pippi46 11 years ago
Would you contact me at lori.venturi@gmail.com
I need to make some object with laser cut and want to have an estimation
thanks
Loredana
hohum 11 years ago
hope this make sense,,
trying to get as much use from the laser as possible, the cutouts will also have their ends melted..
you guys made a fantastic 't'
blhack 11 years ago
jessyratfink 11 years ago
blhack 11 years ago
I guess lasering on cloth is actually really common in production. You can stack many layers of cloth on top of each other, then laser cut them instead of using shears.
scoochmaroo 11 years ago
Rowen27 11 years ago
blhack 11 years ago
