Introduction: Laser Cutter- CUTTING Bumblebee
Every kid want to a fun toy-Bumblebee is definitely the best choice!
Step 1: Required Items
Material:3mm plywood
Laser head:standerd head
Thunder laser used: Machine:Nova35 80watt
Step 2: Setting Parameters:
Processing Mode:Cutting
speed:45mm/s
Cutting power:55%
You can draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your machine.
Step 3: Start Cutting
Place the plywood on the work table of the machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Step 4: Assemble
When the machine is finished, take out the parts of Darth Vader Fighters and put them aside
Step 5: Finished the bumblebee
Show time
