Introduction: Laser Engrave Steel Belt Buckle
We engrave today a stainless steel belt buckle with a diode laser.
For this I use MarkSolid laser engraving paste and 10W Endurance Laser.
- Belt Buckle
- MarkSolid laser engraving paste - I use markSolid 026.M9LP -, others like Molly Dry Lube maybe work, too
- Alcohol to thin the solution
- Brush or Airbrush
- Laser engraver - I use a 10W Endurance Laser
- Belt
Step 1: Preparation of the Buckle
Prepare your MarkSolid and mix it 1:1 with alcohol like isopropanol or ethanol. Clean the buckle with alcohol and cover it with a thin an even coat of the solution. I use paste and no spray, it's a little difficult therefore. You can use an airbrush to do it a little easier. Be careful to not use too much and to get it as even as possible. In the first picture is a bad sample, too thick and with residue in it.
Let it dry.
Step 2: Engrave the Buckle
Use your laser engraving software like LaserGRBL or Lightburn to create your picture. Then engrave the buckle. I used 100 mm/min at 100 % power and 4 passes to be sure that everything is engraved nicely even if the coat is uneven.
Step 3: Finishing: Clean the Buckle
After engraving you can clean the buckle with water or alcohol.
3 Comments
Question 1 year ago on Introduction
Hey Where did you get your belt buckle from?
Reply 1 year ago
I have the buckles from a local leather store together with the belts.
2 years ago on Step 3
impressive. thank you for sharing that!!!
