Introduction: Laser Engraved Wedges
In this project, I’ll walk you through how I laser-engraved a duck camo pattern onto a set of golf wedges. Whether you're customizing your own clubs or doing a one-off for a friend, this step-by-step guide will show you how to prep, engrave, and finish a clean, detailed design on metal. It’s a great way to give your gear some personal style—and maybe even a performance boost (if you believe in looking good to play good!).
Supplies You'll Need
- Laser Engraver – I used a 30W fiber laser, capable of engraving on metal.
- EZCAD + AutoCAD – EZCAD runs the laser, and AutoCAD was used to prep the duck camo vector file.
- Epoxy – Used for re-installing the shafts after engraving or replacing ferrules.
- Torch – For heating the hosel area to remove shafts (if you’re taking them apart).
- PPE (Personal Protective Equipment) – Gloves, eye protection, and a respirator are strongly recommended when using the laser or working with fumes/chemicals.
- Wire Brush Drill Bit – For cleaning oxidation or residue after engraving, or prepping the club surface.
- New Ferrules – Optional but a nice touch if you're removing and reinstalling shafts.
- Vise with Shaft Clamp – For safely holding the club during disassembly or engraving.
Step 1: Disassemble the Club
Before engraving, you'll want to remove the shaft and ferrule. Here's how:
Remove the Club Head:
- Secure the club in a vise using a shaft clamp to avoid damage.
- Use a torch to apply heat around the hosel area. This softens the epoxy inside.
- Once heated, twist and pull the head free from the shaft. Take your time—rushing this can crack the hosel or bend the shaft.
Remove the Ferrule:
- Carefully cut the old ferrule off using a utility knife or rotary tool.
- Clean off any remaining residue or glue.
Clean the Shaft & Hosel:
- Use a wire brush drill bit to clean old epoxy from the shaft tip and hosel bore.
- Blow out the hosel and shaft interior with compressed air to remove debris and dust.
Step 2: Clean Up the Wedges
Before engraving, it’s a good idea to clean up any dings, scratches, or imperfections on the surface. A smoother face not only looks better but also helps the laser produce a cleaner, more even engraving.
Use a Belt Sander to Smooth the Surface:
- Lightly run each wedge face across a belt sander using a fine grit (e.g., 120–220).
- Focus on removing small dings, bag chatter, or casting marks from the back cavity or toe area.
- Keep the wedge moving to avoid creating flat spots or overheating the surface.
- If needed, follow up with Scotch-Brite or hand sanding to blend in sanding lines and create a consistent finish.
Tip: You’re not trying to grind away material—just smooth the surface enough for clean laser results.
Inspect Before Engraving:
- Wipe down each wedge with isopropyl alcohol to remove dust, oils, or sanding residue.
- At this point, the wedge should feel smooth to the touch and be free from major imperfections.
Step 3: Laser
Since wedge shapes vary slightly from club to club—even within the same set—you’ll want to trace each one individually to get an accurate design fit.
1. Photograph Each Wedge:
- Take a clear, top-down photo of each wedge.
- Make sure the photo is as square to the face as possible to avoid distortion.
- Import the image into AutoCAD and scale it to actual size using known dimensions (like face height or sole width).
2. Trace the Club Head:
- Use AutoCAD’s polyline or spline tool to trace the perimeter of each wedge.
- Save the outline as a separate file — this will serve as your engraving boundary in EZCAD.
3. Create the Duck Camo Pattern:
- Find or scan a duck camo pattern you like.
- In AutoCAD, use the image as a guide to replicate the pattern using simple shapes or polylines.
- Vary the pattern slightly between wedges if you want each one to be unique, or use the same layout for a clean matching set.
- Position the pattern inside each traced wedge outline.
Tip: Keep in mind that too much fine detail may get lost during engraving—bold, high-contrast shapes work best.
4. Import into EZCAD & Hatch:
- Export your final design from AutoCAD as a DXF.
- Open EZCAD and import the file.
- Use the hatch tool to fill the camo pattern with engraving lines. Adjust your spacing and angle based on your laser’s performance.
- Set a boundary box if needed to align everything precisely on the club head.
5. Align & Position the Wedges:
- Place the wedge into the laser machine (rotary or jig, depending on your setup).
- Use the outline or bounding box in EZCAD to position the artwork exactly where you want it engraved on the head.
- Double-check focus and alignment before running the laser.
Step 4: Assembly
Once engraving is complete and the club head is cleaned up, it's time to reassemble everything.
1. Prep the Ferrule:
- Apply a small amount of epoxy inside the ferrule.
- Slide the ferrule onto the shaft tip.
- Use a gauge block, club assembly jig, or even a hard surface to press it flush and straight.
- Let it set for a few minutes before installing the head.
2. Epoxy the Shaft Into the Club Head:
- Mix a fresh batch of golf-specific epoxy.
- Apply epoxy inside the hosel and around the shaft tip.
- Insert the shaft fully into the club head, rotating slightly to spread the epoxy evenly.
3. Seat Everything Properly:
- To make sure everything is fully seated, gently tap the butt end of the shaft on the ground a few times. This helps the shaft settle into the bottom of the hosel.
- Wipe away any excess epoxy that squeezes out.
4. Clean Up:
- Use a rag and solvent to clean off the ferrule and hosel area.
- Ensure the ferrule is flush and aligned before the epoxy cures.
Tip: Let the club cure vertically for at least 12–24 hours before use. Don’t rush it—curing time matters for long-term bond strength.
That’s it! You’ve now got a custom set of laser-engraved wedges with a duck camo pattern that stands out on the course and reflects your personal style. From teardown to engraving to reassembly, every step adds a bit of craftsmanship to something most golfers take for granted. Whether you’re doing this as a one-off project or offering custom work for others, it’s a great way to combine design, tools, and love of the game.
If you found this guide helpful, drop a comment below or share your own wedge designs—I’d love to see what you come up with.
