Introduction: Laser Tips & Tricks: Fix Materials
About: — Precision Laser Files for Gift Makers & Laser Workshops For years, we’ve been creating unique, production-ready laser cutting projects. Every design is tested, kerf-adjusted, and optimized for real productio…
How to fixing materails on table of laser machine.
Step 1: Press Down Material Using a Heavy Object
Press down the sheet material to the table laser machine using a hammer or other heavy object. Make sure that the laser head does not hurt the object while moving.
Step 2: Use Simple Clamps of Plywood
Create simple clamps of plywood for fixing material on honey honey comb table. The upper part of the clamps should not exceed 5 mm.
Step 3: Use Simple Clamps of Plywood
Create simple clamps of plywood for fixing material on blade table. The upper part of the clamps should not exceed 5 mm.
Step 4: Use Magnets
Fix carton by magnets on honey comb table of laser engraver.
Step 5: ​Do Not Fix Materials by Fingers!
Do not fix materials by fingers on table laser engraver!
Laser cut ideas at cartonus.com
