Introduction: Laser Phone Stand
This is a simple stand that you can use to hold your phone and that can fit into your pocket.
things that you will need:
0.115 inch thick wood
laser printer
sanding paper
Step 1: Design
First I designed my phone stand using a 3d modeling software and then put it on a drawing sheet. The grooves on the base are 0.115 as that is the width of the wood. As for the grooves on the secondary pieces I suggest that you measure your phone and use that width
Step 2: Cutting
I used a laser printer to cut the design onto a piece of wood
Step 3: Sanding
then to get rid of the burnt residue i sanded it down
Step 4: Enjoy
my design can be used multiple ways to hold your phone to get different viewing angles.
The idea for the phone stand originally came from here:
https://www.instructables.com/id/Easy-DIY-phone-holder-keychain/
