Introduction: Lawn Mover Blade Sharpening Save Money by Doing It Your Self! DIY Easy and Fast
Simple way to save time and Money
Using the links below to shop helps support the channel, Thank you!
“As an Amazon Associate I earn from qualifying purchases.”
Angle Grinder 7.5-Amp 4-1/2 inch with 2 Grinding Wheels, 2 Cutting Wheels, Flap Disc and Auxiliary Handle AVID POWER
GALAX PRO Grinding Discs, 20 Pack by 5PCS Grinding Wheel,10 PCS Cutting Wheel, 5 PCS Flap Disc with 4-1/2” Diameter and 7/8” Arbor for Angle Grinder
REXBETI 25Pcs Metal File Set, Premium Grade T12 Drop Forged Alloy Steel, Flat/Triangle/Half-round/Round Large File and 12pcs Needle Files with Carry Case, 6pcs Sandpaper, a brush,a pair working gloves
Step 1: Remove Blades
Please watch the video on You Tube it helps support the Instructables we do.
Wear Gloves Blades are still able to cut you
Step 2: Grind Blade Egdes
Angle is most important!
Step 3: File Edges
File to remove small burrs on the edges
Step 4: Reinstall Blades
Wear Glove Blades are very sharp, use wood block to hold blades BE CAREFUL!
