Introduction: Layered Beaded and Chain With Swan Necklace Tutorial
You can learn how to make a very pretty layered necklace very easily. All you have to do is follow these easy steps provided!
-jump rings
-beads
-string
-chain
-pliers
-clamps
-clasps
-wire cutter
Step 1: Find the Beads You Want to Pick
Find the color of beads you want for your first layered necklace I would recommend 2-3 colors.
Step 2: Tie the Knot
Tie the knot 5-6 to times so that the beads will not slide of.
Step 3: Start With Your First Colored Beads
Start with the first color of beads you picked and count so you have a consistent number of beads.
Step 4: Add More Beads
Add your second color of beads to your necklace and count that color.
Step 5: Finish the Beads
Finish adding on to your beads until the string is full or to the length of your neck. Tie a tight knot at the end of the necklace. Make sure to tie the knot multiple times.
Step 6: Swan Chain Start
Get a piece of Chain that is the right length for yourself.Cut it with your wire cutter. Put a charm of your choice on to the chain that you have prepared.
Step 7: Adding Together the Two Necklaces
Take the jump rings and attach them in the bead string. Then you want to take your crimps and cramp the two necklaces together!
Step 8: Adding Your Clasp
Add your clasp onto your chain.
Step 9: Your Finished!
Now you can try on your necklace! Your done! Congrats on making your necklace!
