Introduction: Layered Veneer Wood Ring (using a Dremel Lathe)
Finding and keeping hold of my wedding ring has become somewhat of a challenge.
First, I'd ordered the wrong size - and as the ring was bespoke made (from wood, bronze and titanium) I was denied an exchange. I paid for another size, but then the excessive hand washing of Covid caused a seal to break, and back it went for repairs. My newly repaired ring went missing about a month ago.
I couldn't bring myself to buy a third wedding ring when the other one might still be found, so decided to make my own. I find wooden rings - fully wooden or inlaid - to be much more attractive that metal; so, after a little trail and error, I came up with the following technique. I'm very pleased with the result, and drying time aside, it only took 3 days to make.
I hope you enjoy reading.
Required:
- Ruler
- Cutting mat and blade knife
- Veneer strips, 0.5mm thick (assorted wood veneer offcuts)
- PVA / wood glue and spreader
- Spring grip clamps
- Sticky back paper
- Circle drawing guide
- Scroll saw or coping saw
- Drill, with 3mm and 6mm brad point bits
- Sandpaper, various grits
- Tapered wooden dowel of some kind / spatula
Optional:
- Plywood, 3-10mm thick
- Dremel rotary tool
- Dremel workstation 220
- Folding workbench
- Dremel mandrel bit 401
- Dremel sanding bits
To Finish:
- Danish oil
- Clear satin varnish
Step 1: Cut Out Veneer Squares
- Choose which veneers are going to be used and what the ring striation pattern will be (the colour order). For this ring featured, I chose the pattern: light grey, light brown, light grey, dark grey... and so on, plus a final light grey on the end.
- Cut the chosen veneer sheets into 30x30mm squares using a blade knife and ruler (this may need to be scaled for ring sizes greater than 18mm). A combined thickness of 9mm is required, which in my case required 19 squares in total.
Step 2: Glue the Veneers
Glue the veneer squares together, as follows:
- Use PVA / wood glue and a suitable spreader.
- Only glue 2 veneers together at a time, with 30 mins to dry before adding another (best to start early).
- Ensure all the squares are lined up correctly and the grains all run in the same direction.
- Try not to deviate from the chosen pattern.
- Clamp the glued pieces together with spring grip clamps, working from one edge towards the other (squeezing out any excess glue).
- Leave the finished stack to dry for 24 hours after gluing
Step 3: Glue Plywood Practice Blank
Meanwhile, it is a good idea to create a practice blank to use later on. For this I glued together three 30x30mm squares of 3mm thick pine plywood (any scrap wood up to 10mm thick will do). This can make a fairly attractive ring if stained, but it is most useful when used as a practice run.
The practice blank also comes in handy if you clamp it onto the growing veneer stack in order to stop the veneer curling it dries. This can't really be done until the veneer is a few layers deep, or the whole block may stick together.
Step 4: Draw the Template
For the ring template, I used a 30x30mm square of adhesive backed paper, which is easy to peel away with little residue. Before sticking these to the wood stacks, I drew on each:
- A yellow cross marking the centre.
- A ring shape in black fineliner, with an inner circle of my ring size (18mm diameter), and an outside circle of 22mm diameter, in order to produce a 2mm wide ring.
- A red 17mm inner circle and a red 24mm outer circle, for use as cutting guides.
Step 5: Cut the Ring
To cut out the ring(s) I used a scroll saw, though a coping saw would fulfil the same function. Only cut along the outer red circle at this stage, taking care not to cross over the line. It may be easier to cut off only one corner at a time.
It is also worthwhile hanging onto any off-cuts, which can be used to try out different finishes later.
Step 6: Mount the Ring
Next, drill a 3mm hole straight through the centre of the ring (this must be the exact centre, so use the yellow guide lines). It is also best to use some scrap plywood at the back of the ring to avoid any blowout.
Now you can mount the ring onto the Dremel rotary tool and use it as a lathe (what?). Here is my setup:
- Dremel multitool 4300 (other models will work fine).
- Attached to a Dremel 220 workstation
- Clamped into a cheap folding workbench
- And fitted with Dremel mandrel bit 401
Simply screw the ring into the mandrel (guide lines facing out) and you're good to go, but make sure the ring is secured symmetrically, without any wobble.
Step 7: Sanding - Exterior
Set the Dremel rotary tool to a suitable speed (I used 15000rpm, as any slower and the motor caught/stopped), then - while turning - run a strip of 100 grit sandpaper along the ring. It's easier to hold the sandpaper onto a sanding block (such as scrap wood), as the wood will burn if you don't keep the paper moving. The ring can of course be sanded by hand, but that's far less fun.
Continue sanding until the black outer line is met. Once your happy with the size/shape, bevel the exterior edges by moving the paper along it at an angle. This will likely remove the guidelines, but by this point you may need to reposition them anyway.
Step 8: Cut Out the Inside
- Drill through the centre hole of the ring with a 6mm bit, then - if using one - mount the ring onto the scroll saw blade.
- Cut a series of straight lines one from the centre hole up to the red inner circle.
- Remove the last segment using more straight cuts from the centre.
- Remove each further segment by cutting along the red inner circle.
I used my practice ring (see photo) to show the results of cutting out the inner circle all in one go. Your fingers will be the only thing holding this piece down, so cut for too long and the wood will catch. Also, due to the size of the piece you can't use a cutting guard, so there'll only be 2-3mm between your fingers and the blade. Work slowly.
Step 9: Sanding - Interior
The next step is to shape the ring interior. To begin with I used the Dremel rotary tool set to 10,000 rpm with a wide sanding bit, pausing frequently to avoid burning, and moving the ring around with a circular motion. I continued with this until the ring almost fit on my finger.
Then I used a gently tapered dowel wrapped sand paper, aka, a kitchen spatula. The ring needs to get stuck on the sanding dowel (hence, tapered), and whatever you use needs to be perfectly cylindrical. Just pop the ring on and twist until you've sanded down to the desired size, flipping it over every now and then. After that you can bevel the inner edge.
Step 10: Finishing
After I was happy with the shape, I jumped to 400 grit sandpaper for a smooth-over, then up to 1500 grit for a polish.
I decided not to take the practice ring any further, but had experimented with offcuts from the veneer ring; thus, decided to:
- Apply 3 coats of Danish oil, wiped on with kitchen tissue roll, 4 hours apart
- Apply 3 coats of clear satin varnish, wiped on with kitchen roll, 16 hours apart.
And voila, I'm married once again.
