Introduction: Lead Light (Not a LED)
This Instructable is about how to make a lead light that can also be used as an ignition system.
Disclaimer: this is a dangerous project.
1.This is very HOT up to 300 degrees minimum so be careful.
If you get hurt during this project it is not my fault.
Step 1: Materials
Materials:
Battery (at least half an amp other wise it wont work)
Refills for refillable pencil also known as carbon graphite
Switch
Switch
Step 2: Put It Together
Step 1: Make sure your switch is turned off.
Step 2: Put the refill lead between the positive and negative wire and secure it inplace.
Step 3: Keep your hands away from the lead and turn the switch on.
Step 4: there should be smoke for a second (don't breath this in!) and then the lead should turn red.
Each refill should last at least 1 min.
Thanks and goodbye
Thanks and goodbye
