Leaf Vacuum Extension Using a Leaf Blower
Intro: Leaf Vacuum Extension Using a Leaf Blower
Problem: I have gutters that are on the roof of a two story house and even with a ladder, maneuvering to them to clean out leaves is precarious. Here I present my solution. I've taken my leaf blower/vacuum and grafted on a flexible "gutter extender." In all this extends the reach of the vacuum to 7 feet. I have attached a broom handle to the end to help maneuver the top and I put a 90 degree bend to help position the vacuum into the gutter. The materials are wide enough that leaves don't clog it. The total cost for new materials was $15.90. 12.49 for the Flex-A-Spout Downspout and 4.39 for the 90 degree bend. Here's how it's made.
STEP 1: Attach the Flex-A-Spout Into the End of the Leaf Vaccum
I cut the square end off the vacuum and then drilled a hole to fit a bolt going outwards. I put washers inside and outside and fixed it with a nut. I wrapped some weatherstripping around the Flex-A-Spout to make a tight seal. I drilled a hole in the leaf vacuum and then fixed it all together. There is enough play to get the bolt to go in easily. Then I wrapped three layers of duct tape to make sure it is a solid connection. When I don't need the extension, I just remove the duct tape and unscrew the bolt.
STEP 2: Attach the 90 Degree Bend and the Control Stick
The 90 degree bend goes in the end of the extender. Then I used a wire hanger to fasten to the end of the spout. I then stapled the hanger to a broom handle and put duct tape around that to increase the strength.
STEP 3: Drank a Beer
It's thirsty work. This step is optional.
STEP 4: The Grunambuloover in Action
This is a picture of the unit cleaning out a low level gutter. The real beauty is when you are cleaning out the upper stories. I find that i can still use the unit to pick up leaves on the ground too and in some ways, having the extension makes that job easier. But I can take the extension off in about a minute if need be.
27 Comments
NirL 8 years ago
What would happen if you attached the leaf blower to the bottom side of the gutter? :)
Mountainman 1840 8 years ago
howest525 10 years ago
rosewood513 10 years ago
Now I know it will work. Thanks for the video.
balisticsquirel 10 years ago
dUCT tape getting in a shot at the original use. :)
andyrak 10 years ago
I was thinking that perhaps some dryer vent hose with it's end supported by the telescopic painters pole (very light but strong) might be helpful for a design like this as well.
and earplugs for when the motor is on the shoulder lol...
love it!
Grunambulax 10 years ago
I originally thought this up during a recent storm/flood where I had to go on a ladder to clear a gutter that was clogged and flowing into my sons (newly painted) room.
plasMad62 10 years ago
boffincentral 10 years ago
There is a similar commercial product and it has a U shaped piece at the end that goes in the guttering. That will make it a little easier to use, and the machine a lot further away from your ears.
Bubbler 10 years ago
trouble01 10 years ago
Tin Man 10 years ago
I'm getting a bit too old to carry that sort of weight on one arm. Having never been an outside-broadcast TV camera-man, my poor under-developed upper torso would fail in a very short time!
dkkim 10 years ago
Wonder if it would work with a shopvac (either vacuuming or blowing).
rickdf 10 years ago
