Introduction: Leafi a Leaf-shaped Air Quality Sensor
A Leaf But Smarter
Leafi is a leaf-shaped air quality sensor designed to raise awareness about indoor pollution in a fun and educational way. Powered by an MQ135 sensor and a WS2812B LED strip, Leafi visualizes air quality in real time by transitioning from green to redβgreen when the air is clean, red when it's polluted. It also features multiple lighting modes, including ambient animations and a relaxing "lounge mode", with adjustable brightness to match any atmosphere. Fully open-source and 3D-printed, Leafi is eco-friendly, customizable, and perfect for makers, educators, and anyone who wants to make the invisible visible.
Electronics:
- 1X MQ-135 Sensor https://tinyurl.com/yc4zb3pc
- 1X Arduino nano https://tinyurl.com/2wdw9s6p
- 1X Female USB-C Connector https://tinyurl.com/54vz655f
- 1X 330Ξ© resistor https://tinyurl.com/2fp34p7y
- 1X Male USB-C connector https://tinyurl.com/tsd4apfx
- WS2812B 5V Led strip (144 Leds/m) https://tinyurl.com/56exza8c
- 1X 6Γ6 momentary push button https://tinyurl.com/yxjv8f8m
- 1X 5v USB-C Power supply
Tools:
- Soldering iron & solder
- Hot glue gun or epoxy or cyanoacrylate glue
- 2X M3 and 2X M1 screws (or just more glue)
- Wire cutter/stripper
- Optional: translucent filament for the leaf (for best glow)
- Jumper cables
3D-Printed Parts:
- LEAFI_BODY
- LEAFI_BOTTOM_CAP
- LEAFI_BOTTOM
- LEAFI_BUTTON
- 2X LEAFI_LEAF-BICOLOR
- LEAFI_SWITCH_HOLDER
- LEAFI_TUBE
All parts can be printed in PLA
**You can also download my full instructions pdf file :)**
Step 1: π₯ Watch the Demo
RGB vibes for eco-nerds ππ
Step 2: π οΈ Assembly
No screws required for the printed partsβ it's all snap-fit
Female USB-C connector is glued to LEAFI_BOTTOM.stl
π Installing the Button
Insert the LEAFI_BOTTON.stl in the hole, then place the 6Γ6 mm momentary push button on top of the LEAFI_BUTTON.stl. Then, carefully place the LEAFI_SWITCH_HOLDER.stl on top to hold it in place.
β οΈ It might take a bit of gentle persuasion β donβt worry, Leafi wonβt bite! π
Once everything is aligned, I recommend adding a small dab of glue to keep the button nice and snug.
Now your Leafi is ready to click and glow! π
Step 3: π Wiring
Components connected to Arduino Nano
MQ135 Sensor
VCC β 5V
GND β GND
AOUT β A0
WS2812B LED Strip (61 LEDs)
DIN β 330OHM RESISTOR βD6
+5V β 5V
GND β GND
Switch Button (6Γ6mm)
One leg β D2
Other leg β GND
And plug the male usb-c to the arduino and connect it to the female usb-c plug
The Arduino Nano and the MQ135 sensor can be mounted using M3 and M1 screws, but you can also glue them in place instead of screwing.
Step 4: π€ Arduino Code
Upload the code to the arduino nano !
Step 5: π Leafi β Quick Start Guide
Power
π Plug Leafi into a 5V USB-C power source.
Modes
Leafi features 4 lighting modes:
- MEASURE β Color changes based on air quality
- LOUNGE β Ambient color animation
- SPOT β Static light for focused use
- WAVE β Slow, flowing color transitions
πΉοΈ Hold the button to switch between modes.
Brightness
π‘ Short press the button to cycle through brightness levels.
Enjoy the glow!
