Introduction: Learn How to Capture and Handle OS Signals Like SIGINT (CTRL-C) in Python for Beginners
Here we will learn how to capture and handle operating system signals like SIGINT and SIGBREAK on Linux and Windows OS's to control the flow of your python script during execution.
We will use the signal module from Python 3 to capture and handle the OS signals.
- Python 3 Interpreter
- Text editor
Step 1: Contents
- Source codes
- What are Signals
- Checking for available signals in your OS
- Programming Signals on Python 3
- Working of Python SIGINT Signal
- Safely Exiting from an infinite loop in Python
- Original article for Python signal handling Tutorial can be found here
- We also have a YouTube video on Python signal handling Tutorial
Step 2: Source Codes
Instructable code shown here may be partial or pseudo code just enough to highlight relevant techniques or methods.
Please use the full source codes from our Github Repo to avoid errors
Step 3: What Are Signals
Signal is a way in which a program or process (here our python script) can receive information from the Operating System that certain events like a Keyboard Press (CTRL + C ) or a Fault have happened.
Signals are assigned a Integer Value by the OS.
When we press CTRL + C on our Keyboard the Operating System (Both Windows and Linux) will generate a SIGINT signal which is send to the program which is currently active.
Not all signals are available on all systems. Signals differ between operating systems(Linux/Windows)
Step 4: Checking for Available Signals in Your OS.
Since not all signals are available in every OS, It is good to know which ones are available on your system.
Here we will be using Python 3 (Python 3.9.x) and to access the signals we have to import the signal module
import signal # Import signal module
# available signals on our System
valid_signals = signal.valid_signals() # requires python 3.9.0
# returns a SET
print('Number of Available Signals ->', len(valid_signals) , '\n')
for i in valid_signals:
print(i)
The above partial code will print available signals on a particular OS. Download the full codes from Github
Here
returns a set of available OS specific signals which are then printed out.
Available OS Signals on Windows 10
Step 5: Programming Signals on Python 3
To use the Signal received by our script we have to do two things
- Write a Signal Handler which will do the custom processing ,when Signal is received
- Register the Signal with the Signal Handler function
import signal
def your_custom_signal_handler(signal_number,frame):
code to do something
signal.signal(signal.SIGNALNAME,your_custom_signal_handler)
Here we will be using the SIGINT signal to control the execution of our Python 3 script.
SIGINT Signal is common to both Windows and Linux systems and helps us to run our code on both Windows and Linux Systems.
Please use the code from Github
def SignalHandler_SIGINT(SignalNumber,Frame):
print('SignalHandler of signal.SIGINT')
#register the signal with Signal handler
signal.signal(signal.SIGINT,SignalHandler_SIGINT)
while 1:
print("Press Ctrl + C ")
time.sleep(1)
Here
is the Signal Handler ,So when the Signal SIGINT is generated this function is called and the print() statement under is called.
The statement
registers the signal handler function SignalHandler_SIGINT(SignalNumber,Frame): with the signal SIGINT signal.SIGINT
Please note that the code should be run under the command line.
If you use an IDE like Thonny or IDLE, the IDE tend to interfere with the reception of the SIGINT signal
Step 6: Safely Exiting From an Infinite Loop in Python Using CTRL + C (SIGINT)
In this example we will learn how to safely exit from an infinite loop in Python 3 using signals.
In some application like Serial Port Data Acquisition System Software written in Python we have to query a sensor or Microcontroller like Arduino or Raspberry Pi board continuously in a infinite loop.
In those applications we can use the SIGINT signal (CTRL +C) to interrupt the infinite loop and close the application safely without a resource leak.
Check this article Exiting From An Infinite Loop In Python Using CTRL + C (SIGINT) for more info
Getting out of the infinite loop in Python on Windows
Getting out of the infinite loop in Python on Linux using SIGINT
This technique is used to build a Python based serial port data acquisition system here
