Introduction: Learn How to Stealth
This is very disappointing, I saw not ONE Instructable on how to stealth / sneak / or how to remain undetected. I decided to make one of my own and first Instructable on how to remain undetected!
Step 1: Clothing
Clothing is very very important on how well you're sneaking. Colors of clothing MUST match and also have to match the environment (i.e. you're in a white room, wear white clothing). Also make sure your clothing fits perfectly. Any loose clothing that hangs over your pants is fine AS LONG as you TUCK them into your pants and stretch a little bit to make sure you have enough room to move around quietly. Now the pants, Pants that fits perfectly fine around the waist and extra clothing that does NOT go over your shoes is perfect, but make sure its not too tight around the legs and butt while you're moving. Heres the most difficult part on sneaking, SHOES! You must always relay on your shoes while sneaking, but finding the right shoes may be rather difficult. For example GRIP shoes are UNACCEPTABLE, They make too much noise and also cannot move across the floor while sliding/moving. Also the shoes MUST fit, cannot be loose at all costs, always tie them TIGHTLY before sneaking to prevent them from falling off! Now to move on how to sneak.
(Note: Sometimes underwear clothing can have a major effect on your pants while sneaking.)
(Second Note: Loose objects on clothing can be harmful unless it matches with your clothing, does not make the slightest noise, and does not reflect light.)
Step 2: Sneaking
Ah yes, my favorite hobby. Sneaking is very effective to get into places without drawing any attention (if you're good enough!) I will explain a few basics on sneaking.
Beginners - New to sneaking? Well, if you want to be effective I'd recommend starting out as crawling. It is very useful on how to start out, I do this myself to remember how to sneak efficiently, Reasons to why. Crawling brings your close to the floor, listening for creaks and how you are positioned. When sneaking MOVE quietly and lightly! Your hands must be very light to find the creaks on the floor and AVOID them at all costs, your knees simply follow the direction of your hands.
Standards - Ok, so your going to try on your feet, huh? Well like in the beginners note, move lightly and quietly! Make sure you use your TOES to find a creak on the floor, If there is a creak, avoid it. If there is no creaks, Proceed carefully.
Step 3: Stance
Stance is also important on how well you want to sneak. In fast paced type of sneaking you want to have your legs slightly bent but not in a position of standing straight up or crouching. A more efficient way of not being noticed is Crouching, It is often used but make sure you use one of these stances while sneaking.
Note: If you must get up from crouching to a more balanced stance, always move slowly.
Step 4: Sum It All Up
Well I've explained the most important basics to sneaking but sneaking depends on what type of situation you're in. I'll post more ways on how to sneak to avoid the following
-Avoiding Cameras
-Avoiding Guards
Although it does seem rather difficult because they will be listening and watching all the time. So practice on these skills and learn to improvise and stay out of peoples sight.
Good luck everyone and remain in the shadows for best performance.
-Avoiding Cameras
-Avoiding Guards
