Introduction: Leather Ax Sheath
Today will show the design of the holster for the ax.
The first half video is a design. And the second half will do.
For this, I use laser cutting. If anyone does not have a machine, they can download PDF, DXF to cut with a cutter.
Step 1: Design
I copied an ax with a pen and paper.
Then scanned to the computer.
Import the file into CorelDRAW.The line is based on the model.
Copy and expand and draw a circle of 1 millimeter to the edge for stitching.
And imagine the design.
Step 2: Cut Out
I use a laser cutter. For quick and easy work.
If you do not have a laser cutter, that's fine.
You can download pdf file to print A4 size. And cut with a knife cutter.
Laser Cutting Tip: Use adhesive paper off the top so that the pads do not bounce and dirty.
Step 3: Sewing and Assembling
Bring everything together
equipment
- Buckle Size 20 mm.
- Skull
- Thread
- needle
- Drill
- Eyelet 4 mm.
Note: I have an iron skull with leather trim. If you have something else to replace it. Depending on ideas
Step 4: Finishing Step
Show on the wall. And enjoy watching videos.
