Introduction: Leather Minimalist (Quarantine) Card Holder
This is my take on how to "quarantine" a card. I created this minimalist card holder to keep my most used card at hands reach. With this I can use the card and simply keep sanitazing it, everytime I use it.
The minimalist card holder uses very few materials. You will need
- Leather
- Ruler
- Box cutter
- Contact cement
- Needles
- Waxed nylon thread
- Wing divider
- Stitching chisels
- Hammer
- Snap fasteners
- Swivel hook or carabiner
- Leather corner cutter (optional)
- Leather acrylic paint (optional)
Step 1: Pattern
On a cardboard, I cut a square using a standard size credit card and adding 2/8" to 3 of the borders. This is to have space for sewing on 3 sides of the leather.
There is a really good Instructables Class by MikaelaHolmes on how to cut the leather and installing snap fasteners.
Step 2: Cutting the Leather
First, mark the pattern on the leather. Then cut a little bit outside the outlines in order to cut over the draw line with more ease.
For the swivel, measure the inside of the ring and cut a strip of leather that can pass through it. On the photos there is an example with a carabiner - it's the same procedure.
For the strap to secure the card, I cut a 5/8" strip of leather. It is 9" long, at the end it has to be trimmed to the final lenght.
Step 3: Start Putting It All Together
Mark a 1/8" line around 3 inside sides of the leather. Apply contact cement to the leather. Depending on the type of glue you use, it will have diferent instructions of how to use it. In THIS ONE, you have to wait for it to be dry before puting it together.
OPTIONAL: Using a round corner cutter ( or with the box cutter) round 2 of the corners of the card holder.
OPTIONAL: Paint the borders of the card holder with acrylic paint.
Using a wing divider trace a line around the 3 glued borders. Punch the holes for sewing the leather using the stitching chisels.
Install the snap fastener to the leather strap and punch the holes for sewing 1" away from the fastener.
Step 4: Sewing Time
Start sewing from the top corner. Remember to sew the swivel holder and the leather strap to the card holder while sewing around the perimeter.
Step 5: Finishing the Strap
With a card inside of the card holder, mark the end of the strap and cut it. Using some preasure, mark the position of the snap on to the leather and punch the leather. Install the other part of the snap fastener and finish the end of the strap to your liking.
Step 6: Final Product
You have finished! Now you will be able to "quarantine" a card.
Hope this will be usefull for other people.
