Introduction: Leather Wallet From a Boot
Don't throw your old leather boots away! Make a minimalist leather wallet / cardholder out of it. You can also use old leather baseball gloves, bags and so on. By the way, leather is very robust and sustainable material. Okay, let us make one :)
Step 1: Materials and Tools
Materials
- Old leather boots
Tools:
- Cutter
- Ruler
- Hammer
- Half round punches
- Scratch awl
- Wood slicker
- Chisel (4 mm)
- Leather glue
- Wing divider
- 2x needles
- Sew thread
- Tokonole leather finish
- colorless leather fat (Clear leather dressing)
- Rotary tool (for example: Dremel) or sandpaper
- Edge beveler
- Lighter
Step 2: Removing the Leather From the Boots
The fun part :D. Destroying the boots! STOP! That was a joke! Carefully removing the leather from the boot. You need big flat pieces. Remove / rip out all fabrics wich are glued to the leather. Clean the leather with a leather cleaning brush (optional).
Step 3: Tracing Out the Pattern
Download free minimalist leather wallet pattern, print and cut them out.
You can download them HERE
Transfer the pattern on each leather piece. Use the scratch awl tool.
Step 4: Cutting Out the Leather Pieces
Use the ruler, cutter and half round punches to cut the leather pieces out.
Step 5: Sand and Burnishing the Edges
Sand and burnishing the edges of the front and back pocket. Use tokonole leather finish and the wood slicker to burnishing the edges.
Step 6: Glue the Leather Pieces Together and Taking Off Sharp Edges
The areas to be glued on the smooth side should first be roughed with a sharp blade. Glue all pieces together. After gluing use the edge beveler for taking off the sharp edges.
Step 7: Punching Holes and Sewing
For sewing use the saddle stitch technique. On YouTube you can easy find a bunch of tutorials. Finally snip and burn the ends.
Step 8: Burnishing Edges and Finishing the Product
The leather has lost a lot of fat, so it has to be treated. To protect the leather use clear leather dressing or beeswax leather fat.
Step 9: The Finished Product
We are done! I would be glad to see your leather boots wallets :)
*** My Links ***
Instagram: https://www.instagram.com/paracord.wolf/
