Introduction: Leatherman Wave: Hidden Lanyard Piece
The leatherman wave, one of the best tools someone can get. Most people use it for years and years and it never fails. Leatherman sells a lanyard piece as an accessory, But there's one thing a lot of people don't know, there is a hidden lanyard piece, it even swivels! I will explain in the following steps how to find it.
Step 1: The Saw
First get the big bit out of the inside. Then fold out the saw. You will see a circle thing where the point of the saw used to be.
Step 2: Press It Out
Use the flat head side of bit to press the hidden lanyard piece out.
Step 3: Finally!
It's a bit hard to press it out, but here it is!
21 Comments
4 years ago on Introduction
I bought the pocket clip and lanyard accessory combo thinking I would be able to fit both together, but seems it is either or. So thanks for this. It is really difficult to get out. I ended up using the back edge of another knife to fill gap and push hard but it is worth the effort.
12 years ago on Introduction
I have an old Wave that doesn't have this feature--bummed.
It would be good if the original post could point out that this 'structable is for the original Wave as others have noted.
8 years ago
fully agree with you..i am having it from many years ..even though i do not want to use it..so it it like new
9 years ago on Introduction
I actually cut the hidden lanyard loop off and replaced it with the one that comes with the pocket clip. Now i have both pieces on my wave.
10 years ago on Introduction
found it, thanks!!!!
this is my 5th or 6th wave i have owned and i have NEVER found this before !!!!! and i use it EVERY DAY!!!! thanks so much !!
11 years ago on Step 2
thats great had wave for about 4 yrs something new thank you
11 years ago on Introduction
awesome!
11 years ago on Step 3
It's there for the leatherman charge too :) thanks for figuring it out and sharing.
Awesome, thanks for that, thumbs up :)
My "Surge" has a similar lanyard loop. It's right by the saw/file piece as well. Good Job finding that!
the charge has it too! now i don't need the lanyard piece that i bought.... what to do, what to do. too many options now.
I bow to your wave kung fu. I'm not sure I'll ever use it but a great find!
Reply 12 years ago on Introduction
I am trained by the master
Thank you! I got a wave yesterday and was dissapointed at the (apparent) lack of a lanyard ring. I ran a search to see if someone had hacked one and was pleasantly surprised to find this 'ible.
I am happy to help, how do you like yours?
My Surge has one as well! Never even saw it there. Of course, I've never fully disassembled the tool. It's MUCH smaller than the wave lanyard ring. Probably to make room for the larger interchangeable saw/file blade.
Thanks!
The older wave has a lanyard attachment located between the large flat screwdriver and the philips screwdriver (at least mine does)
I thought I knew every inch of my Wave. I guess I was wrong.
