Introduction: Led Switchback Circuit
I googled this circuit the whole Internet and not found how to do it, and finally got a simple circuit, and would like to help you
Step 1: What You Will Need !!
- 1n4007 Diode
- 5 pin car relay
- Capacitors 6,600uf (minimum), I used 3 of 2,200 microfarad
- wires
- led drl for test
- soldering iron
- electronic skills
Step 2: Solder the Capacitors
solder the capacitor terminals in parallel, positive with positive and negative with negative like the image
Step 3: Positive to Drl
connect the pin 87a on the positive DRL and pin 30 to the positive battery, connect the pin 85 to the negative batery too together with the capacitors like the image
Step 4: Diode
connect the 1n4007 diode on pin 86, as in the picture (the negative side of the pin 86) and connect the other end to the positive turn signal wire
Step 5: Connecting on Relay
connect the negative of the capacitor on pin 85 of relay, and the positive on pin 86
Step 6: You Finished !!!
check out the links are correct, any questions do not hesitate to ask !!!! very simple ...
