Introduction: Led Desk Lamp
Hi,
Here you can see how I made my desk lamp.
What you need:
- wooden plate
- led strip 1 meter
- carton, steel, aluminum, plastic plate
- glue
- jigsaw
- switch if you want
- soldering iron
votes are appreciated!
Step 1: Sawing the Wood Parts
You can saw the side plates with a jigsaw. I added an 1:1 drawing in PDF.
Step 2: Cutting the Other Parts
I used carton for the back side. It's cheap and easy to cut and when you paint it, it looks good too.
Step 3: Glueing Toghetter
Glue 2 offset blocks between the 2 wooden sides for firmness. Next place the carton in the grooves and add a bit of glue.
Step 4: The Ledstrip
I cut a ledstrip of 1 meter in 2 pieces and and solder them with a small wire togheter. I don't use the connector for the controller but solder it too.
