Introduction: Legion Go D-Pad Replacement
Download and Print D-Pad replacement.
https://www.thingiverse.com/thing:6364915
6mm X 2mm rare earth magnet
X-Box elite metal D-Pad Hat
Step 1:
Remove 4 screws. These are screwed into plastic, and made of cheap metal. Use firm pressure, and go slow.
Step 2:
Use a pry tool. This is an easy spot for entry.
Step 3:
4 more screws and a rumble pack connector. Again into plastic, be judicious. R2 will come loose.
Step 4:
Pry here and pull the RB off.
Step 5:
Remove PCB. CAUTION: Ribbon cable is TINY. When you remove the PCB, unfold it like you were opening the cover of a book. You can leave it attached or flip the clasp on the PCB to remove it. I removed it the first time, but it was painful getting it in and closed. Remove the controller release button.
Step 6:
drop in 3D Printed D-Pad replacement. loosely install RB.
Step 7:
Goes back together much the same way it came apart. If you have gotten this far, you can figure it out.
