Introduction: Lego Assassin's Creed Phantom Blade
Hello everyone! I decide to make the Phantom Blade from the latest Assassin"s Creed Unity before it comes out, and it's the most powerful hidden blade because it has a mini crossbow on it, the gif will show you how it works. Let's move on!
Step 1: Step1: the Main Body
to build this, you will need to build the original hidden blade
to make the hidden blade mode works, and you don't need to build the top of the hidden blade.
You will need to build another blade for this.
Step 2: Step2: the Crossbow
For this part, you will need a rubber band and cut it .
I recommend you to use the one i used.
Step 3: Step3: the Lock
This the lock when you are using the crossbow. When you are not using it, do the same thing from the last 3 images. When you are using the crossbow, take off the thing from the last three images and put on the lock.
Step 4: Step4: the End!
Wow! you are done! to shoot the blade you pull it back and release. If you want to lock it, put on a tile to lock it.
Don't forget to vote for me and check out my other stuff, I will make more things!
Please leave me some comments by the way! I'll see you guys next time.
