Introduction: Lego Bench
This lego bench makes a simple and easy alternative to chairs which you may be out of (like me).
Step 1: Get Materials
Get:
- 1 by 6 plate (x1)
- 2 by 6 plate (x1)
- 1 by 2 plate (x1)
- 2 by 2 plate (x1)
- 1 by 6 flat plate (x4)
- 1 by 2 plate with bar on the end (x4)
- 1 by 2 with clip on the side (x2)
Step 2: The Base
First, take the 2 by 6 plate and place a 1 by 2 plate one the top middle. Second, place the 1 by 2 plates with clips on them on both sides of the 1 by 2 plate (clips outward). Third, place a 1 by 6 plate (not flat) on the other side. By now it should look like the second image. Finally, place 1 by 6 plates (flat) until it is covered.
Step 3: The Backrest
Set out the following pieces next two each other in the following order: 1 by 2 plate with bar (extended outward), 1 by 2 plate with bar (extended outward), 2 by 2 plate, 1 by 2 plate with bar (extended outward), 1 by 2 plate with bar (extended outward). Then connect them using the remaining 1 by 6 pieces.
Step 4: AYD
Connect both parts and you're done. It's perfect for your waiting rooms and and parks. I have put it in my bank.
HEY!!!!
