Introduction: Lego Board Game
This is a game that you can customize in any way that you want. For 2-6 players or how many you want.
2-6 minifigs (as many minifigs as you are playing with) (you can customize any way you want to)
minifig stuff (as many as you want) (items that minifigs can hold and use)
1 ruler (optional)
1 marker or duck tape (you can also just do a chessboard)
2 die (yes that is the plural of dice)
lego vehicles (optional)
Step 1:
I set up my game as having all the items in the middle and the players starting at the corners.
Step 2: Items
I added items and each item had a different effect. I will go through them later.
Step 3: How to Make the Board.
You can make the board by using the ruler to make 1" squares on a piece of paper or a wooden board if you really liked the game.
Step 4: Set Up
You can place the items and spawn points anywhere you want on the board. To make it more fun you can try placing the loot and items as far apart as you can.
Step 5: Play
To play you take the two dies and roll them on your turn. You then move the number of spaces as shown.
To make it more challenging you can only play it with one dice.
Step 6: Power-ups
the power-ups were all stuff I had. You can try to get the same ones or find your own.
Step 7: Snow Ball
The snowball can move like a rook in chess.
It has a one-time use.
Does one damage.
Step 8: Binoculars
Add to the gun to increase range.
nothing on its own.
unlimited uses
Step 9: Hammer
Throw it like a queen can move in chess
does two damage
has 2 uses
Step 10: Knife
does a circle damage
5 uses
1 damege
Step 11: Baton
Does one damage
strikes right in front of the player
7 uses
Step 12: Gun
the gun shoots in a straight path like a queen.
does 2 damage
4 uses
Step 13: Bow
has half the range as the gun
two damage
4 uses
Step 14: Sword
swing it in a circle
does two damage
has 8 uses
Step 15: Scythe
2 damage
6 uses
Step 16: Ender Pearl
throw it and land at most five spaces away
no damege
one use
Step 17: Speed Hat
times the number on the dice by 2
5 uses
no damage
Step 18: Bomb
set down a run for a four by four explosion
kills any player in radius even you
one use
Step 19: Player
the player has three hits a life
they have two lives
when killed the first and second time they drop whatever they have with them.
uses the dice to move.
