Introduction: Lego Building Table
Hi! I'm a lego builder and I think it would be awesome to make a lego building table! You will need many blocks but you will probably have them because there basic blocks.this might be a little tricky and you will need to have the patience and you will need to be a good builder to make it. Have fun!
You will need:
-At least 2 lego platforms
-thin short and long blocks
-the fat blocks that are usually six piece block.
-and any extra things you want to add to it
Step 1: Start With the First Leg of the Table
Stack the six piece block up. Try to stack it up taller. I prefer 33 blocks tall.
Step 2: Then Make the Second Leg of the Table
Repeat step 1
Step 3: Make a Tower in the Middle Between the Two Legs
Try to make the tower tall enough to be the height of the legs of the table
Step 4: Add Platform
What I did was got two platforms and put them together. Since the platform doesn't connect with the other blocks on the bottom of it, I connected it with a different block connecting with the top of the leg.
Step 5: Add Two More Legs
There is now five legs to keep it steady.
Step 6: Build a Supply Area on One Part of the Table
On one part of the top of the platform, make a little supply area. It will keep it nice and organized. You can add some things to it if you would like.
Step 7: Building Area
On the other part of the table, that will be your building area. Build what ever you want
Step 8: Enjoy!
Thank you and have fun!
