Introduction: Lego Candy Dispenser
I made a lego candy dispenser for a desk top for a quick snack while you are working. :D
#1 many 2 by 4 stud legos
#2 many 2 by 2 stud legos
#3 many 1 by 2 stud legos
#4 10 slanted legos
#5 Many 4 by 1 stud legos
#6 many 1 by 1 stud legos
#7 one 6 by 6 stud plate
#8 Two 4 by 10 stud plates
#9 One 1 by 10 stud plate
#10 One 8 by 8 stud plate
#11 One 4 by 4 stud plate
#12 many 3 by 2 stud legos
Step 1:
build a 2 1/2 inch wide by 4 inch tall tower. But make sure to only make 3 sides. Then after that add the 6 by 6 plate to the bottom.
Step 2:
Now create a box that is 3 inches wide by 2 inches tall from your legos of course. This will be the hopper for the candy. And also make sure to leave the top and bottom of the box open.
Step 3:
Now attach the box to the top of the tower make sure its on all the way.
Step 4:
create a ramp out of your 10 slanted peices. make sure to add support for the ramp to stand.
Step 5:
After you make your ramp insert it into the tower.
Step 6:
After that make the "landing pad" from the both of the 4 by 10 plates. First put the 2 plates together side by side. and connect them with the 4 by 1 legos. Then create a border with the 4 by 1 legos and use 1 2 by 1 lego to fill in the final gap
Step 7:
Now attach the "landing pad" to the tower at the base make sue the 6 by 6 plate doesnt cover the whole bottom of the tower
Step 8:
For this step take the 4 by 4 plate and the 1 by 10 plate and attatch the together. This will be for filling the dispenser.
Step 9:
Now crate the cover for the front of the tower. Now make two exactly the same pillars that are 1 1/2 inches tall by 3/4 of an inch wide. then use a 1 by 4 lego to attatch the pillars. After that attatch the pillar to the bottom of the box.
Step 10:
After that step put the 8 by 8 plate on the top as a lid but dont press down otherwise you cant get the lid off
Step 11: The Final Step
To fill the candy dispenser use the the thing from step 8 put it up with 3 1 by1 1 legos stacked on eachother. Then fill with recommend candies such as skittles and m&m's. Then once filled remove the thing from step 8 and enjoy!
