Lego Christmas Lights
Intro: Lego Christmas Lights
Do you want to give your Lego Home a Start to the Holiday season? Get A Lego Fiber Optic Unit,Motor,Battery pack,wires, 1x16 Beam.
I hope you will like the Extra Touch!
STEP 1: Get All the Pieces
Get the Battery pack or power source. The power Source can be mainly A RCX Brick,Battery Box. This will produce the Light!As well as move the Motor
STEP 2: Then Get the Light and Motor
This step is when you get the Fiber Optic unit And Motor.
Put the Axle of the motor into the side of the Fiber optic unit and connect the wires to the motor , Fiber optic unit(FOS)
and , in this case, One RCX Motor port.
STEP 3: Now Connect the Fibers
Take the Fibers to the FOS.
then take the pegs and insert the Fat end of the Fibers into thepegs. The in Every other Hole , Stick the Pegs into the holes.
STEP 4: Add the Lights
Give a general description of the Instructable
STEP 5: Add the Lights
turn it on and watch the Fun!
7 Comments
krcorcoran 9 years ago
Just to be clear to make this project I need:
Lego part 6637 a Lego Fiber Optics Element
A Lego Motor ::Which one? 8203 the Power Functions motor set? the L motor? Train Motor? Any motor. I can't find one that looks like yours::
An RCX brick...maybe? :: If it's only used for power can I just use a Lego battery pack??? How much power do I need, can I attach multiple Lego Fiber Optic Elements in a series or daisy chain connection if I have to much voltage?::
Any Lego Fiber Opics Cable...maybe??
Lego wire... maybe the extension wire Part 8886? but it doesn't look like it...
Pegs and Beam... actually easy to find on the Lego site so that's fine
For someone with out a box full of random Lego components this Instructable doesn't have enough information for me to obtain the parts. Which sucks cause it's a REALLY cool idea.
Can you go back. Make a list of parts (with part numbers or official part names) needed to make this? Then list parts that can be subsituted? Like
Parts needed:
Power Soure (RCX or LEGO Battery pack with ##volt output)
Motor (L motor part #### will work or Motor #### will work)
So on and so forth.
Please? This is really cool. Thanks!
led235 16 years ago
led235 13 years ago
jeffconnelly 16 years ago
led235 16 years ago
Dexter339 16 years ago
led235 16 years ago
