Introduction: Lego Headphone Holder
I needed a headphone stand and I thought, why not make it out of legos? It's a usefull and basic build you can make yourself instead of buying an headphone stand.
Only 25 pieces are needed for this build. I gave each piece a number and a color so it would be easier to build.
Step 1:
Gather the pieces first, then you can join the pieces for the red part.
Step 2:
Make the green sides. There are two slightly different pieces you need to make on this part.
Step 3: Join All Together
Just join the three pieces and the build is done. The only thing you need to do is to attach it under a desk to use.
Step 4: Attach It Under Your Desk
You can either use screws or a double sided tape to attach it under your desk. I used only double sided tape for mine but you can use both of them if you want to. If you are going to use both of them to attach it, don't forget to put the tape first and then screw the screws after. But double sided tape worked just fine for me. Just don't forget that screws won't work on honeycomb filled desks. For example, most of the ikea desks are like this (I put a photo to show what honeycomb desks look on the inside.)
