Introduction: Lego Keychain (The Easy Way)
Want to make a Lego Keychain? Now you can, with the Lego Keychain Instructable, (The Easy Way) by Ninjaaa -- NO DRILL REQUIRED! Just a few Lego bricks, 3 steps... and you'll be set to go!
Step 1: Do You Have Enough Pieces?
You will need:
. 2 x 6 thin with pre-made holes in it
. keychain
. 2 x 5 thin or pieces that add up to it
Step 2: Add the Keychain
Simply said there. Add the keychain. You can put it in any hole you like, but I chose the top, which I believe is the best spot.
Step 3: Add the Other Pieces
As you see, there are still MEAN, GREEN, HOLE MACHINES in the lego piece. Use the pieces to patch up those holes on the back.
