Introduction: Lego Microphone Money Hider
Make an easy Lego Microphone Money hider! No one will suspect it!
- Four White Lego 2 x 4 x 5 Half Cylinders with 1 x 2 Cutout
- One White Round Lego 4 x 4 Brick with 4 Side Pinholes and a Center Axle Hole
- One Lego 4 x 4 Cylinder Hemisphere
- Two Round Lego Dark Gray 4 x 4 Plates with a Hole in the Middle
- One Round Lego Orange 4 x 4 Plate with a Hole in the Middle
- One Lego Black Brick 4 x 4 Round with Hole
- One Lego Pearl Dark Gray Barrel with Axle Hole
- One Lego Dark Stone Gray Axle 8 with End Stop
- Cash (Rolled Up)
Step 1: Assembling the Base
First stack your Two Round Lego Dark Gray 4 x 4 Plates with a Hole in the Middle on top of each other.
Then take your Black Brick 4 x 4 Round with Hole and stack it on top of the two, round, dark gray pieces you just stacked.
Step 2: Assembling the Body
Take your Four White Lego 2 x 4 x 5 Half Cylinders with 1 x 2 Cutout and make two stacks of two.
Then attach that to the base you just made.
Step 3: Assembling the Top
Take your Round Lego Orange 4 x 4 Plate with a Hole in the Middle and put it on the top of the body.
Then take your Lego Pearl Dark Gray Barrel with an Axle Hole and put it on top of the round orange brick you just placed down on the body.
Now take your Lego Dark Stone Gray Axle 8 with End Stop and put it into your White Round Lego 4 x 4 Brick with 4 Side Pinholes and a Center Axle Hole and stick the axle rod down the top of the build.
Finally, place your Lego 4 x 4 Cylinder Hemisphere on top of the Build!
Step 4: Add the Money
Now split the body of the build in half and put in your roll of money so that the axle rod goes through the middle of the money roll!
Step 5: Finished
So whenever you need some money just grab out your Microphone!
