Introduction: Lego Minfig Portrait Studio
I’ve played with Legos all my life, which means I’ve made, AND taken a part, a lot of minfigs. Wouldn’t it be awesome to capture those creations… With a Lego camera… With a flash… and a button… that uploads pictures to my cloud storage! Yep I really made one and I’ll show you how to make one too.
I get a commission on purchases made through some of these links:
https://amzn.to/2YM5Udu Raspberry Pi Zero W
https://amzn.to/3jsNCpl Micro SD Card
https://amzn.to/2QKtPoV Arducam Lens Board for Raspberry Pi Camera
https://amzn.to/2YO3WJg Pi camera ribbon cable, full size down to Pi zero connector
https://amzn.to/34Nnd1z 10cm cable pack
https://www.adafruit.com/product/1578 500mAh Lithium Ion battery
https://www.adafruit.com/product/3196 Pimoroni LiPo SHIM
https://www.adafruit.com/product/1009 Colorful Round Tactile Button Switch Assortment - 15 pack
If you have never worked with a Raspberry Pi Zero before, you will want to pick up these items as well to help interface with it for initial setup and debugging:
https://amzn.to/3gDeG3q MicroUSB to USB 4 Port Black OTG Hub for Raspberry Pi Zero
https://amzn.to/3jLuMdf Mini HDMI to HDMI Adapter Cable
https://amzn.to/2DiS8Yg 4K High-Speed HDMI Cable
https://amzn.to/2QB7FWg CanaKit 5V 2.5A Raspberry Pi Power Supply
Step 1: The Electronics
The button – We will need a sacrificial 2x2 stud lego that we will glue the button to. Make sure that you have selected 2 normally open pins on the button housing and solder wires with female connectors to it. Then I used 2 part epoxy to secure the button to the lego. Connect those wires to Pi Zero GPIO pins 34 and 36.
LiPo Shim – Slide the shim PCB over pins 1 through 12 and solder each lead with the Pi Zero.
The LED – Solder the resistor in line with either of the LED leads. Connect the (+) plus lead side to Pi Zero pin 4 (+5v) and (-) negative lead to pin 6 (ground).
Step 2: The Software
- Install the standard Raspberry Pi OS image on the Pi,
- Connect a monitor, mouse, keyboard, the Pi camera, and power it up.
- After the initial login and reboot continue on.
- Test that your camera module / ribbon cable is connected and working. Raspberry Pi OS includes a helpful tool to take a picture:
raspistill -t 1 -o 1.jpg - Join your wifi network
- Clone the code I wrote from https://github.com/vincestechshop/lego-minfig-por... to /home/pi/lego-minfig-portrait-studio/
Add:
python3 /home/pi/lego-minfig-portrait-studio/camera.py
to your /etc/rc.local file above the exit 0 line. - Install and configure rclone https://github.com/rclone/rclone
- Connect the button and LED
- Test that everything is working
Run: python3 /home/pi/lego-minfig-portrait-studio/camera.py
Press the button
Expect to see an initial flash and then a flash when it finishes uploading the picture to the cloud.
For a bit more detail please see the full length video
Step 3: The Lego Housing
The fun part! You can see the parts I used for my build and you can watch how I assemble it all in the full length video. I'd love to see what you come up with!
If you like this project, be sure to subscribe to my channel:
Step 4: Have Fun!
Get some great shots of your masterpieces
