Introduction: Lego Portal GLaDOS Frame (+Rocket Turret!)
This instructable will show you how to create a structure upon which a GLaDOS can be hung on. (For those who don’t know, GLaDOS is the main antagonist of the portal series). I will also show the rocket turret which she uses in the final battle of Portal.
DISCLAIMER : I will NOT show how to build GLaDOS herself, but I have created an example of her, which you are free to copy.
See attached image, as this is such a big build that it would take a long time to list out...
Step 1: Rocket Turret
THIS IS MY OLD DESIGN OF THE ROCKET TURRET - I HAVE ANOTHER INSTRUCTABLE SHOWING THE UPDATED DESIGN!
Here is the link : https://www.instructables.com/Lego-Portal-Rocket-Turret-V2/
Step 2: Floor
If you want to copy my floor, then here it is (I will also attach the rocket turret in this step). Just to point out, I am using a 48x48 base plate to build this. I would recommend only using ONE base plate to build this on, as building it on multiple base plates causes it to not be as secure.
Step 3: Frame
Step 4: For Extra Stability...
Take out the 6x6 round plate and place it on top of the technic bricks as seen in this photos.
Step 5: Example GLaDOS
Here are some example pictures. I have put an extra rotating tile at the ‘connection point’, and attached an example GLaDOS. Of course, you can edit this build to suit your needs, but here is the main concept. Enjoy!
