Introduction: Lego Portals
A logo portal is a piece made of legos and it makes a way into an imaginary world. These are super fun and simple to build. They are also super pretty and I often use them for decoration! :)
Step 1: Gather Your Supplies
You are going to need a fair few amount of legos all in one color. This is optinal, but I like to have a few extra cool legos, for example I am making a green one and I am using some flower legos to add to the theme of it.
Also you are going to need your imagination, which all of you have, to connect the legos in ways that are intresting to look at and fun to build!
Step 2: Make the Base
The base is going to need to use two layers of legos to keep it all connected. So for the first base arrange some of the legos into a relitivly small square. It is best to avoid little 2x2 because they are esier to use on the top. After that put another layer on top this should keep all of the bottom pices stedy so that they do not fall apart.
Step 3: Make the Top
You will need to add steps so that lego people can get to the portal, you will need to make a hole in one of the sides big enough so that lego people can get through.
Step 4: Add the Extras!
This is the part where you use those extra cool pices, I am going to use flowers, but if you where making a fire portal, then you could use flames of transparent blockes.
