Introduction: Lego Torch Case
things your going to need are: lego, torch and a base and now on to the building!
Step 1: Measure
measure how big the walls need to be e.g mine is 16 x 8 and 9 blocks high
Step 2: Building
Next you have to to do the building the best way to build is putting 1 2x4 block half way on on top of another one then for the end you can put a 2x2 block next to the top/bottom block like in the image shown above.
Step 3: The Front
the front is going to need a gap in the middle so you can see the light and turn it on the walls can be just normal but don't forget that gap!
Step 4: Sides and Back
sides, they are like the walls but with less pieces but here you should make sure you make a little window to see if anything is going on on the inside and the back is the same as the front but with no holes in it just a plain wall.
Step 5: Roof
the roof is just a normal roof but it needs a hole in the middle to poke your fingers in and fix anything on the inside and if your torch has a hook (like mine) you need a hole for it to hang on to things!
