Introduction: Lemonade Cow
A lemonade cow! Very nice for a party to entertain the children. By milking the cow, the children can get their own lemonade.
2x wooden plate 110cm x 160 cm x 9 mm
6x wooden beam 4 cm x 4 cm x 40 cm
2 wooden plate 35 cm x 35 cm x 9 mm
1 white bucket with flat bottom
4x Kerbl Valve with Teat Red (https://www.agradi.nl/kerbl-ventiel-met-speen-rood-2-stuks.htm)
paint (white primer, Pink (or mix red and white), blue, yellow, black)
paint brushes
permanent marker black
pencil
jigsaw
a beamer to project the image of the cow on the wooden plate
12x 5 cm screws
6x 3 cm screws
Step 1:
Use a beamer to project the picture of the cow onto the wooden plate. Draw the edge of the cow with a pencil.
Step 2:
Use the jigsaw to saw out the cow. Use the cut-out cow as a cover example for the other cow
Do this for both wooden boards. After this, please cover the cut-out cows with the primer paint.
Step 3:
When the paint has dried, use the beamer again to make the details of the cow. Little pieces can be colored with the permanent marker.
Horizontal rotate the image on the pc on the next plate so you have a nice cow-look on both sides of the plates.
Step 4:
paint the cow!
Step 5:
drill 4 holes in the bucket and attach the teats.
Step 6:
With the jigsaw, saw a circle out of the board (35 x 35), so that the bucket will fit well.
Screw the beams to the wooden boards.12x 5 cm screws
And screw the cut out circle board to the beams. 6x 3 cm screws
Put some lemonade in the bucket and off you go! Have a nice party!
