Introduction: Length Converter
Hi. This tutorial will teach you how to make a length converter in Visual Basic. A length converter is a tool that can be used to turn Miles into Kilometres or Metres into Kilometres. This application uses Arithmetic Operators which are equations such as division and multiplication. I recommend this tutorial to people who are familiar with Visual Basic. If you are new to Visual Basic you can still try this.
This you need:
This you need:
- Computer.
- Microsoft Visual Basic.
- Basic knowledge of Visual Basic.
Step 1: Creating the Project
Step 1: Open Microsoft Visual Basic.
Step 2: Create New Project by clicking on New Project or press Ctrl+N.
Step 3: Pick Windows Form Application and name it "Length Converter".
Step 4: Rename Form1.vb to "Length.vb". This is for Easy use.
Step 5: Rename Form1 to "LengthForm" and make the Text "Length Converter". This is for Easy use.
Step 6: Resize it to your liking. I have made my one '500, 300'.
Step 7: Insert a Label at the top of the Form and make the name "Title" and make the text "LengthConverter"
Step 8: Insert two Buttons. One in the centre. Name it "ConvertButton" and make text "Convert". The second button is optional. Place it at the top right hand conner and name it "ExitButton" and make text "Exit"
Step 9: Insert two ComboBoxes, Place one on the left and the other on the right. Name the one on the left "LengthList1" and the one on the right "LengthList2". Make the text on both of them "SelectUnit"
Step 10: Insert two TextBoxes and place them underneath the ComboBoxes. Name them "UnitText1" and "UnitText2". Leave the Text blank.
Step 2: Getting the Basic Code
Step 11: Double click on the 'ExitButton'. This will make a new Private Sub which will activate when the button is clicked.
Step 12: Insert the following code:
Step 14: Insert the following code:
'This will close the application' Me.Close()Step 13: Double click the 'ConvertButton'. This will make new Private Sub which will activate when the button is clicked.
'These are the Boolean for the Length in the first box' Dim Mile1 As Boolean Dim KM1 As Boolean Dim M1 As Boolean Dim CM1 As Boolean 'These are the Boolean for the length in the second box' Dim Mile2 As Boolean Dim KM2 As Boolean Dim M2 As Boolean Dim CM2 As Boolean 'These are the inserted numbers that will be converted' Dim Num1 As String Num1 = UnitText1.Text Dim Num1 As String Num2 = UnitText2.Text
Step 3: Converting the Units
Step 15: Insert the following underneath the previous code:
'What it is converting'
If LengthList1.Text = ("Mile") And LengthList2.Text = ("Kilometre") Then
Mile1 = True
KM2 = True
End If
'The equation for the conversion'
If Mile1 = True and KM2 = True Then
UnitText2.Text = Num1 / 0.62137
End If
If LengthList1.Text = ("Mile") And LengthList2.Text = ("Metre") Then
Mile1 = True
M2 = True
End If
If Mile1 = True and M2 = True Then
UnitText2.Text = Num1 / 0.0062137
End If
If LengthList1.Text = ("Mile") And LengthList2.Text = ("Centimetre") Then
Mile1 = True
CM2 = True
End If
If Mile1 = True and CM2 = True Then
UnitText2.Text = Num1 / 0.0000062137
End If
If LengthList1.Text = ("Kilometre") And LengthList2.Text = ("Mile") Then
KM1 = True
Mile2 = True
End If
If KM1 = True and Mile2 = True Then
UnitText2.Text = Num1 * 0.62137
End If
If LengthList1.Text = ("Kilometre") And LengthList2.Text = ("Metre") Then
KM1 = True
M2 = True
End If
If KM1 = True and M2 = True Then
UnitText2.Text = Num1 / 0.001
End If
If LengthList1.Text = ("Kilometre") And LengthList2.Text = ("Centimetre") Then
KM1 = True
CM2 = True
End If
If KM1 = True and CM2 = True Then
UnitText2.Text = Num1 / 0.000001
End If
If LengthList1.Text = ("Metre") And LengthList2.Text = ("Mile") Then
M1 = True
Mile2 = True
End If
If M1 = True and Mile2 = True Then
UnitText2.Text = Num1 * 0.000621317
End If
If LengthList1.Text = ("Metre") And LengthList2.Text = ("Kilometre") Then
M1 = True
KM2 = True
End If
If M1 = True and KM2 = True Then
UnitText2.Text = Num1 / 1000
End If
If LengthList1.Text = ("Metre") And LengthList2.Text = ("Centimetre") Then
M1 = True
CM2 = True
End If
If M1 = True and CM2 = True Then
UnitText2.Text = Num1 / 0.01
End If
If LengthList1.Text = ("Centimetre") And LengthList2.Text = ("Mile") Then
CM1 = True
Mile2 = True
End If
If CM1 = True and Mile2 = True Then
UnitText2.Text = Num1 * 0.000000621317
End If
If LengthList1.Text = ("Centimetre") And LengthList2.Text = ("Kilometre") Then
CM1 = True
KM2 = True
End If
If CM1 = True and KM2 = True Then
UnitText2.Text = Num1 * 0.00001
End If
If LengthList1.Text = ("Centimetre") And LengthList2.Text = ("Metre") Then
CM1 = True
M2 = True
End If
If CM1 = True and M2 = True Then
UnitText2.Text = Num1 * 0.01
End If
'If converting into same unit then the valve will be the same'
If LengthList1.Text = LengthList2.Text Then
End If
