Introduction: Let's Build a Robot!
I've been building stuff like this since I was about ten or so years old... and I love it!
It's amazing how fabrication techniques have improved in the last few years. Inexpensive hardware, 3D printers, and awesome boutique electronics stores like Adafruit, SparkFun, and Seeed Studio have opened a Pandoras-box of Awesome.
Are you ready to build your robot? Please make sure to read through the entire Instructable before making any purchases - parts are listed throughout.
If you have any questions, let me know - I'll do my best to help. Want to see ROBOB (ROB-OB) in action?
https://vine.co/v/hBhqD1ZQHLm
Ding ding ding... let's go!
Step 1: 3D Part Printing
The robot is comprised of about two dozen parts that can be printed on just about any 3D printer that has a 4.5 X 4.5 inch build platform; PLA or ABS is up to you.
Here's a link to the model on TinkerCAD...
Are you new to 3D printing? Printing all these parts is going to take a good chunk of time - the bigger your build platform the better. To save you a little bit of time, I've broken the model down into printable parts - get all the bits-n-bytes over at Thingiverse.
http://www.thingiverse.com/thing:104962
Like I said, you can use PLA or ABS... here are the types I used.
Blue Pro-Series PLA
http://www.matterhackers.com/store/3d-printer-filament/pro-series-blue-pla-filament-1.75mm
White Pro-Series PLA
http://www.matterhackers.com/store/3d-printer-filament/pro-series-white-pla-filament-1.75mm
Natural Pro-Series PLA
http://www.matterhackers.com/store/3d-printer-filament/pro-series-natural-pla-filament-1.75mm
Blue Pro-Series PLA
Step 2: Servo to Arm Connector
Here's a little nugget that might help you manage the transition from printed parts to injection molded / metal parts.
I originally tried to print a mount... to connect the bolted revolute joint directly to the servo. It was all kinds of wobbly - and didn't work. The vertical shear-strength and tolerances of printed parts just weren't going to cut-it.
I decided to 'integrate' the nylon connector that comes with the servo into the print... bingo!
You'll need to trim the servo horn down a bit and then snap it into the mate. Then, glue the two parts together and you have a very strong and reliable transition from the servo to your printed arm. Use the tiny screw provided with the servo to attach the arm to your robot.
Do you know where robots keep their armies? ...up their sleevies.
Step 3: Arms Assembly
You'll need a eight #6-32 PC screws to attach the digits to the hand; three digits on one side and one for the thumb. The hand is isometric, 'flip' assembly for the other over and you're good to go. You're making great progress - give yourself a hand!
StarTech #6-32 PC Screws
http://www.amazon.com/gp/product/B00028CAIK/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
When the hand is done, move-on to the forearm. I found an odd connector in my wife's scrapbooking box... and decided to use it with the bolted revolute joint. It turned out kinda cool.
1/4 inch Chicago Posts
http://www.amazon.com/gp/product/B003O5GPHU/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
When connecting two bolted revolute joints together - put a nut in one and a screw in the other and twist the them together. Use a screwdriver to adjust them to a sweet-spot; not too loose or too tight.
M3 Nut / Screw Set
http://www.dipmicro.com/store/SET-M3X8PPSZ
Top the arm with the connectors you completed in the last step.
M3 Nut / Screw Set
Step 4: Feet and Legs Assembly
This is a quick and easy step... assembling your footies. Grab the foot cap and apply the color accent with a bit of super-duper glooper.
Flip the cap over and fill it full of something heavy. I'm using washers from our local home improvement store; buying a box is typically less expensive than buying onsies or twosies.
When you're ready, snap the base and cover together and use some 1/2 inch chicago posts to hold the foot to the leg.
1/2 Inch Chicago Posts
http://www.amazon.com/gp/product/B003O996A4/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
Step 5: Torso Assembly
Super-duper glooper the torso base, belt, and mid-section together... I get the parts almost together except for a little space and then let the glue 'wick' into the groves; hold for 30-40 seconds.
You'll need to decide where you want to drill a hole for the power - I used a 15/32 inch drill bit. Don't go to fast, you might melt and/or crack your part.
2.1 mm Panel Mount Barrel Jack
http://www.adafruit.com/products/610
Add the leg plate and bolt the torso to the leg loop.
When we get to the electronics you'll see why I decided to add the Adafruit logo.
Next are the shoulder caps and neck ring.
Do you remember how we glued the servo horn for the arm connector? Here is the same approach with the head. When you get this done, add the servos... they should snap into place; you'll need three. Two for the torso and one for the head/neck.
Turnigy 9g Servos
http://www.hobbyking.com/hobbyking/store/__9549__Turnigy_TG9e_9g_1_5kg_0_10sec_Eco_Micro_Servo.html
Arrrrms... matey - add the arrrrrms and torso cap.
Turnigy 9g Servos
Step 6: Head Assembly
Screw that puppy in place... why do we say 'puppy?' Why not wombat or kiwi?
This crazy looking three-armed-thing is a transducer - which we'll mount in the head. It's a kind of speaker... more about that later.
HiWave Transducer
http://www.parts-express.com/pe/showdetl.cfm?partnumber=297-220
Insert the 8x8 LED matrix into the eye socket and add some M3 screws to hold it into place... or glue it - whatever suits you.
Mini 8x8 LED Matrix w/I2C Backpack (blue)
http://www.adafruit.com/products/959
Glue the mouth ring to the head cap - what's that crazy thing with the wires coming out of it? We'll cover that in a bit. Close up the head and it should fit nice and snug against the torso.
HiWave Transducer
Step 7: Electronics
It's time to transform your robot into an Internet of Things!
You'll need power, something to drive your servos, a 'brain,' LEDs, a 'voice,' and an audio amplifier for starters.
5V 2A Power Supply (good)
http://www.adafruit.com/products/276
5V 10A Power Supply (best)
http://www.adafruit.com/products/658
Arduino UNO
http://www.adafruit.com/products/50
5mm LEDs
http://www.adafruit.com/products/301
16-channel Servo Driver
http://www.adafruit.com/products/815
3.7 Watt Stereo Audio Amplifier
http://www.adafruit.com/products/987
EMIC 2 Text to Speech Module
http://www.adafruit.com/products/924
Argh! My batteries need recharging... I will have to continue this Instructable next week! Stay tuned!
Arduino UNO
5mm LEDs
