Introduction: Let's Build an Emergency! Box
What is an Emergency! Box
By definition, a box containing the equipment, supplies, and medications needed to provide an initial assessment and manage life-threatening conditions. In this case, our box provided a sound and light beacon during emergency situations such as storms, car accidence, etc.
I also hope that you follow our Power Breadboard Projects series and that is why you are here to turn the prototype into a finished product. This article will provide everything you need to know to turn any prototype into a finished product. We will use our knowledge about the 555 timers for this project.
- Aluminum Enclosure
- 4 Binding Postes
- On/Off/On Switch
- 2 Solderable Boards
Step 1: Build the Circuits Onto a Solderable Board
First, lay down the components.
Then solder the path accordingly to the schematic.
Step 2: Cut the Pattern for Speaker and Light Onto the Enclosure
First, print the pattern.
Then, snap your finger!
Step 3: How to Wire the Emergency! Box
First look at the schematic.
Then solder accordingly.
Finally, connect the battery before closing the unit.
Reassemble the enclosure after testing.
Step 4: Conclusion
I hope that this article will provide everything you need to know to turn any prototype into a finished product. For this project, I use the last couple of projects' information for this project. The Emergency! Box is a module system in terms of which more light and sound modules can be connected to the Emergency! Box to expand the area covered.
