Introduction: Let's Turn a Vintage Camera Into a Decorative Web Cam and Light!
I was at my father's house recently and he had a box of stuff that he had cleaned out of his garage. Knowing that I'm a sucker for junk, he offered it to me as my wife shot him dirty looks. There was a couple of old Sony three way speakers with crossovers, an old cast aluminum ice bucket, a collection of shot glasses, a broken CB, a rats nest of wall warts and a Polaroid 250 Land Camera. I loaded the loot in my car while the wife fumed and dad chuckled at conning me into saving him a trip to the dump.
The speakers were stripped from the cheap chipboard cabinets and put in the speaker bin (I have a speaker wall project that I'm saving them for), the ice bucket became the new cat dish, the shot glasses found a home on the art shelf, the CB got stripped for useful parts and the wall warts got bagged and labeled and put in the power supply bin. The camera was cool looking but I had no immediate use for it so it ended up on the junk shelf (I mean one of the junk shelves... OK... in the junk room... no really, it's organized, I swear... mostly).
When I saw the Vintage contest I knew I had to come up with something cool so I went to raid the junk room, err, 'Inspiration Zone'. I came across an old Logitech web cam. I have been wanting to hook it up in a permanent place on my work bench to record time lapses of builds, so I decided to mod it into something cool and retro for the contest. Then I remembered the old Land Camera and everything clicked. I'd put the sensor and lens assembly from the web cam into the Land Camera and wire some LEDs into the flash unit as a video light.
Be sure to read the notes on the pictures for additional details. Let's dig in and see what we have!
*Note*
I have received a few comments about ruining a valuable vintage camera. While I appreciate the concerns, I assure you this was not a valuable camera. The lens was scratched and a battery had been left in it and leaked in the battery compartment. It had been stored for who knows how long in a shed in the woods and it was on its way to the dump. I rescued it from the tip and made a fun project out of it. Relax.
Step 1: Disassembly of the Land Camera
My basic plan was to remove the guts from the shutter assembly on the front of the camera and install the webcam there. First I removed the strap. Then I opened the camera up and removed the screws attaching the bellows to the shutter assembly. I released the bellows latch and gently extended the shutter assembly and retracted the bellows back into the camera body. I removed the Shutter assembly from the support frame and opened it up. After removing the lens I removed the mechanical and electronic parts from the shutter body. I removed the rear lens and then reassembled the empty camera body.
I set the removed parts aside for later sorting. This is very important! I have boxes for all kinds of parts and general classification of parts. This makes finding that weird switch assembly from that old boat I scrapped two years ago much easier at three in the morning when I desperately need it. I justify it this way- as long as I collect things actively by sorting and culling them rather than just piling stuff around then it's OK. A supply is stocked, a collection is curated, but a hoard is just acquired.
Step 2: Disassembly of the Web Cam
Disassembly of the web cam is pretty straight forward- remove some rubber plugs, remove a screw, pop it apart and you're done. Remove the board with the sensor and microphone from the holder and focus ring assembly. This is what we need.
Step 3: Putting Them Together
In order to fit the camera board into the shutter housing I had to modify the body by grinding a 'bulge' into the lens hole. The board was taped and glued in place. A power LED was installed in the hole where the light sensor was in the original camera with power jumpers for the LEDs in the flash unit. The USB cable was fed through the bellows into the camera body.
Step 4: Wiring the LEDs in the Flash Unit
The flash bulb unit was stripped and two blue LEDs were installed with a switch and power and ground leads going to the shutter housing.
Step 5: Finishing the Camera
A mat board disc was cut with holes drilled for the sensor and microphone. This was installed and held in place with the black and chrome lens rings. Now I have a decorative web cam. When I redo my workbench I will mount an old tripod head on an upper corner to cover the work area for time lapses and sped up assembly sequences. It's also convenient for online hangouts and video conferencing. Best of all I've taken an impersonal bit of one-size-fits-all tech and made it unique. It's not just a web cam- it's a story. What has that camera seen since the late sixties when it left the Polaroid factory? What more will it see now that it's been given a new life? While the Land Camera was obsolete, so was the low res Logitech web cam. By combining two redundant pieces of technology that were bound for the trash I've created something that will outlive the useful life of either item. I made this! If it breaks I'll be much more likely to fix it because I'm personally invested in this thing.
This is what the maker movement is all about- taking charge of your consumption and having your way with devices. We don't have to settle for the designs of passionless wage hacks- we can reimagine everything to fit our personal esthetic. Pick up a glue gun, disrupt disposable consumerism and make the future bright.
Runner Up in the
Vintage Contest
Home Technology Contest
11 Comments
9 years ago on Introduction
Why would you destroy a Polaroid 250, that's one of the nicer Polaroid cameras with a glass lens and a metal body. Should have used one of the cheaper models that are like 5 dollar cameras instead of a 50-100 dollar camera. Also a quick tip for people, don't do this to a Polaroid 180,185,190,or 195. Those are $200 cameras that are the nicest Polaroid cameras Polaroid ever made except for the 600se.
I feel you !
My heart is bleeding, seeing the pictures of that Polaroid being gutted.
In Germany, a working 250 easily goes for a 100 €.
I actually went on line to check the value of the camera before I started this project. With the shape it was in it was no where near being worth $50-100. It had been 'rode hard and put up wet' and the lens was scratched. Plus it was free where as a $5 camera would have cost $5. At the end of the day it's just an obsolete instant camera- it's not like a butched a Hasselblad or something.
While the median final sale price (not asking price) of Polaroid 250's on that well known auction site is $60. The maximum for working units is $299. The maximum for broken/parts units is $40, which is what you're describing your camera as.
As far as them being obsolete. A camera for which film is still being manufactured can hardly be called obsolete.
As far as you have to pay $5 for a similar camera. I'd have gladly traded you one of my beautiful, but lower end, Polaroid Automatics to modify instead. I'd even have picked up the shipping for both. Many Polaroid aficionados would do the same.
That Ziess viewfinder would be worth an entire lower end Automatic all by itself. So anyone else considering this 'ible, if you're looking at using a 250, 350, 360, 450, or any of the models mentioned by mammo300 above, please check around. Even if the film should ever stop being manufactured, these are quality cameras that can still be modified for other photographic purposes.
Great idea! As concerns the question of value: I think your approach is spot on. I have a similar aversion to chucking stuff out. However, one must be realistic when assessing the value of "collectable" stuff. In your case an unrepairable camera has got a second life and retains its authentic looks (not a replica).
Does this mean I should not use my Kodak 3-A Autographic Kodak Jr.
I have not been able to find film for it or what film it uses. and not sure what else it could be used for.
I have been wondering what to do with it.
Ebay has become the defacto price guide for collectibles. If you are into photography, many old cameras can be converted into pinhole cameras. If it's not a valuable antique and you have no use for it as-is do whatever you want with it. Things are just things- they're only real value is in their use.
This is very cool! I love the humour especially the part where you say your wife 'shot him dirty looks'! Classic! Maybe a few photo's or even an Instructable on how you organise your 'makers junk'?
Hmmm... an organized chaos Instructable- that's a challenge. I'll have to work on that.
9 years ago
You are a man after my heart, you pack rat! My wife does the same look thing when I accept gifts of maker gold!! Great job on the camera and the instructable.
I love this! Turning an old camera into a new camera!
