Introduction: Letter Wall Decor With LED Lights
If you want something special for your wall just find a pallet get LED lights and create magic! :)
See the instructions video here!
Enjoy:)
Step 1: List of the Stuff You´ll Need
TIP: Get the battery charged LED lights - it´s safer and will look better!
Use piece of double-sided tape to stick the battery holder on the inside of the pallet.
Step 2: Staining the Pallet for Letter Color
Step 3: Applying Sticky Vinyl Letters (with a Help of Transfer Foil)
TIP: You can get these letters online for cheap and transfer foil is usually included.
Use plastic scraper (second photo left upper corner) to attach the letters to the transfer foil (and later to the pallet).
Step 4: Painting Over the Letters & Removing Them (so Much Fun!)
TIP: Use craft knife to remove the letters.
Step 5: Drilling the Holes for LED Light Bulbs
TIP: Count the bulbs first then drill :)
Step 6: Installing the LED Lights
TIP: Be very carefull with the stapling because you can damage the wire! Use tape if you´re not confident with staple gun.
Step 7: Enjoying the Result!
Looks nice switched off and even better switched on!:)
