Leveling Assembly TAD 330
Introduction: Leveling Assembly TAD 330
Here you will learn how to create the leveling assembly shown above with 4 parts and 1 assembly
Step 1: Base Plate Sketch
First Part! The Sketch for the base plate can be made through rectangles or lines to the dimensions given in the photo above. The curves on both the inside and outside can be made by using the fillet tool in the sketch mode.
Step 2: Base Plate Sketch Extrusion
Use the Extrusion tool to extrude the sketch by 75 mm.
Step 3: Base Plate Hole Sketch
Create a sketch of a circle as shown above.
Step 4: Base Plate Hole Extrusion
Extrude the hole sketch all the way through
Step 5: Base Plate Third Sketch
Create a sketch of a circle and 2 lines as shown above.
Step 6: Base Plate Third Sketch Extrusion
Extrude the hole sketch through the first section
Step 7: Lifting Block Sketch
New Part! Make a rectangle based on the dimensions shown above
Step 8: Lifting Block Extrusion
Extrude the Sketch 100 mm
Step 9: Lifting Block Sketch 2
Make a sketch on the side of the previous extrusion with the dimensions shown above
Step 10: Lifting Block Sketch 2 Extrusion
Extrude the sketch all the way through
Step 11: Lifting Block Fillets
Add fillets to all areas (3mm radius)
Step 12: Lifting Block Circle Sketch
On the top add a sketch of a circle with these dimensions
Step 13: Lifting Block Circle Sketch Extrusion
Extrude the circle sketch 5mm
Step 14: Lifting Block Fillet
Add a fillet onto the previous sketch (Radius of 3mm)
Step 15: Lifting Block Circle Sketch 2
Add another sketch of a circle with the dimensions above in the center of the other circle
Step 16: Lifting Block Circle 2 Extrusion
Extrude that circle sketch all the way through
Step 17: Adjusting Screw Sketch
New Part! Create a sketch like the one above with an overall length of 72mm
Step 18: Adjusting Screw Revolve
Revolve the previous sketch!
Step 19: Adjusting Screw Hexagon Sketch
Make the sketch shown above
Step 20: Adjusting Screw Extrusion
Extrude the previous hexagon sketch 9 mm
Step 21: Adjusting Screw Chamfer
Create a chamfer of 1 mm
Step 22: Adjusting Screw Thread
Add a thread to the end of the screw
Step 23: Sliding Block Sketch
New Part! Create the sketch as it is shown above
Step 24: Sliding Block Sketch Extrusion
Extrude the first sketch 100 mm
Step 25: Sliding Block Sliding Block
On the side of the last extrusion recreate the sketch shown above
Step 26: Sliding Block Second Sketch Extrusion
Extrude the Second Sketch all the way through
Step 27: Sliding Block Third Sketch
On the top create the sketch shown above
Step 28: Sliding Block Third Sketch Extrusion
Extrude the Third Sketch all the way through
Step 29: Sliding Block Hole Sketch
Create a sketch of a hole in the center of the back of the part
Step 30: Sliding Block Hole Extrusion
Step 31: Sliding Block Fillets
Add 3mm radius fillets to the areas shown
Step 32: Assembly: Screw to Base Plate
Assembly Time! Constrain the Screw to the base plate with the areas of constraint shown
Step 33: Assembly: Sliding Block to Base Plate
Constrain the sliding block to the base plate with the areas of constraint shown
Step 34: Assembly: Lifting Block to Base Plate
Constrain the lifting block to the base plate with the areas of constraint shown
Step 35: Final Assembly Complete!
Good Job!
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
