Li-Fi Enabled Text Communication Using Arduino
Introduction: Li-Fi Enabled Text Communication Using Arduino
About: hIOTron is an IoT Based company that offers IoT Platforms, IoT Solutions, IoT Training.
Li-Fi enables shifting data utilizing optical communication likewise visible light
Supplies:
Hardware Components
Arduino UNO
LDR Sensor
Keypad 4*4
16*2 Alphanumeric LCD
I2C Interface module for LCD
5 mm LED: Red
Software Components
Arduino IDE
Step 1: About Project
Li-Fi utilizes visible light as a communication medium for the release of data. A LED can serve as a light source and the photodiode serves as a transceiver that sustains light signals and sends them back.
By Checking the light pulse at the transmitter side, we can transfer unique data patterns. This phenomenon happens at much high speed and can't be seen via the human eye. Then at the receiver side, the photodiode or Light-dependent resistor (LDR) changes the data into valuable data.
Li-Fi Transmitter Using Arduino
Arduino changes the data into binary pulses which can be served to an LED source for transmission. Then this information is supplied to LED light which transmits the visible light pulses to the receiver side.
Li-Fi Receiver Module
On the receiver side, the LDR sensor sustains the visible light pulses from the transmitter side and changes them into interpretable electrical pulses, which are supplied to the control unit.
Internet of Things Course Training will help to know about IoT Concepts.
Step 2: Run a Code
//Transmitter Side: #include const byte ROW = 4; const byte COL = 4; char keyscode[ROW][COL] = { {'1', '2', '3', 'A'}, {'4', '5', '6', 'B'}, {'7', '8', '9', 'C'}, {'*', '0', '#', 'D'} }; byte rowPin[ROW] = {A5, A4, A3, A2}; byte colPin[COL] = {A1, A0, 12, 11}; Keypad customKeypad = Keypad( makeKeymap(keyscode), rowPin, colPin, ROW, COL); char keycount = 0; char code[5]; void setup() { Serial.begin(9600); pinMode(8,OUTPUT); digitalWrite(8,LOW); } void loop() { char customKey = customKeypad.getKey(); if (customKey) { Serial.println(customKey); if (customKey == '1') { digitalWrite(8,HIGH); delay(10); digitalWrite(8,LOW); } else if (customKey == '2') { digitalWrite(8,HIGH); delay(20); digitalWrite(8,LOW); } else if (customKey == '3') { digitalWrite(8,HIGH); delay(30); digitalWrite(8,LOW); } else if (customKey == '4') { digitalWrite(8,HIGH); delay(40); digitalWrite(8,LOW); } else if (customKey == '5') { digitalWrite(8,HIGH); delay(50); digitalWrite(8,LOW); } else if (customKey == '6') { digitalWrite(8,HIGH); delay(60); digitalWrite(8,LOW); } else if (customKey == '7') { digitalWrite(8,HIGH); delay(70); digitalWrite(8,LOW); } else if (customKey == '8') { digitalWrite(8,HIGH); delay(80); digitalWrite(8,LOW); } else if (customKey == '9') { digitalWrite(8,HIGH); delay(90); digitalWrite(8,LOW); } else if (customKey == '*') { digitalWrite(8,HIGH); delay(100); digitalWrite(8,LOW); } else if (customKey == '0') { digitalWrite(8,HIGH); delay(110); digitalWrite(8,LOW); } else if (customKey == '#') { digitalWrite(8,HIGH); delay(120); digitalWrite(8,LOW); } else if (customKey == 'A') { digitalWrite(8,HIGH); delay(130); digitalWrite(8,LOW); } else if (customKey == 'B') { digitalWrite(8,HIGH); delay(140); digitalWrite(8,LOW); } else if (customKey == 'C') { digitalWrite(8,HIGH); delay(150); digitalWrite(8,LOW); } else if (customKey == 'D') { digitalWrite(8,HIGH); delay(160); digitalWrite(8,LOW); } else; } } //Receiver Side: #include #include LiquidCrystal_I2C lcd(0x27, 16, 2); #include #include void setup() { pinMode(8, INPUT); Serial.begin(9600); lcd.init(); lcd.backlight(); //lcd.backlight(); lcd.setCursor(0, 0); lcd.print(" WELCOME TO "); lcd.setCursor(0, 1); lcd.print(" CIRCUIT DIGEST "); delay(2000); lcd.clear(); } void loop() { unsigned long duration = pulseIn(8, HIGH); Serial.println(duration); if (duration > 10000 && duration < 17000) { lcd.setCursor(0, 0); lcd.print("Received: 1 "); } else if (duration > 20000 && duration < 27000) { lcd.setCursor(0, 0); lcd.print("Received: 2 "); } else if (duration > 30000 && duration < 37000) { lcd.setCursor(0, 0); lcd.print("Received: 3 "); } else if (duration > 40000 && duration < 47000) { lcd.setCursor(0, 0); lcd.print("Received: 4 "); } else if (duration > 50000 && duration < 57000) { lcd.setCursor(0, 0); lcd.print("Received: 5 "); } else if (duration > 60000 && duration < 67000) { lcd.setCursor(0, 0); lcd.print("Received: 6 "); } else if (duration > 70000 && duration < 77000) { lcd.setCursor(0, 0); lcd.print("Received: 7 "); } else if (duration > 80000 && duration < 87000) { lcd.setCursor(0, 0); lcd.print("Received: 8 "); } else if (duration > 90000 && duration < 97000) { lcd.setCursor(0, 0); lcd.print("Received: 9 "); } else if (duration > 100000 && duration < 107000) { lcd.setCursor(0, 0); lcd.print("Received: * "); } else if (duration > 110000 && duration < 117000) { lcd.setCursor(0, 0); lcd.print("Received: 0 "); } else if (duration > 120000 && duration < 127000) { lcd.setCursor(0, 0); lcd.print("Received: # "); } else if (duration > 130000 && duration < 137000) { lcd.setCursor(0, 0); lcd.print("Received: A "); } else if (duration > 140000 && duration < 147000) { lcd.setCursor(0, 0); lcd.print("Received: B "); } else if (duration > 150000 && duration < 157000) { lcd.setCursor(0, 0); lcd.print("Received: C "); } else if (duration > 160000 && duration < 167000) { lcd.setCursor(0, 0); lcd.print("Received: D "); } }
Be the First to Share
    • Microcontroller Contest
    • Automation Contest
      Automation Contest
    • Make it Glow Contest
